Tuner recommendation
Old Feb 3, 2021 | 12:07 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by 1Fordman
Actually I didn't give up on this thread, I do thank those of you that gave good positive information. I had a long informative conversation with the folks at Fuel Moto yesterday and they headed me in the direction I want to go.
5+ stars for Fuel Moto.
Thank you very much for your purchase and for the kind words, if you need any assistance tuning we're happy to assist.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Feb 4, 2021 | 05:36 PM
user 47363638's Avatar
user 47363638
Originally Posted by fuelmoto
Power Vision is the tuner of choice for many top dyno tuning shops as well as individuals performing their own tuning. Support is not limited to where it was purchased; tunes and software can be downloaded from the Dynojet website, they also have a support portal, and Power Vision products are supported by in the hundreds (if not thousands) of Dynojet dyno tuning centers around the globe. Fuel Moto also offers high level support to our customers and dealer network.
Tune and software wise Power Vision has extensive tuning definitions and the maps are fully adjustable by the user. Depending on the year/model bike and tune build strategy you typically have access to 80+ tuning tables. You also have two different available software platforms; WinPv and PowerCore. If you want to take a test drive you can download the actual tunes & software at https://www.dynojet.com/
Power Vision is also the only tuning device with the ability to integrate directly into the Dynojet Dynoware RT dyno hardware. Power Vision plugs in and streams HD ECM data into the Power Core dyno control, data center, & tuning software, you can also integrate peripherals such as wideband O2's from AT-Pro, Target Tune, any other Dynojet wideband device, or you can use the wideband O2's from the dyno itself. There's also a handful of tuning utilities to assist the tuning process including Tune Lab which even allows users to write their own tune routines, scripts, & corrections.
Hey not to derail the thread, but I’m hearing conflicting reports on whether or not to tune after adding an exhaust and air cleaner on an M8, what would be your experience
Old Feb 4, 2021 | 05:45 PM
Weeboy1's Avatar
Weeboy1
Or you could perhaps start your own.....
Old Feb 11, 2021 | 11:18 AM
60Gunner's Avatar
60Gunner
I'm well aware of the fact people tend to chose these things based on popularity, user interface, etc. not necessarily which one is best.
Ask about tuners and invariably FM gets brought up. I'm buying a tuner based on which is best. Period. FM's map support may be a reason for some to buy the PV but not me.
No one seems to want to talk about things like the crank tooth setting or timing(knock retard) that still doesn't work in the PV and most likely never will at this point. Or the fact that the TTS reads data from the ECM 10 times faster than any other tuner including the PV. That's going to result in a better calibration. Especially when not tuning with a dyno.
FMs map support means nothing to me. It's just a base map and from what I've seen, the same one is used for multiple different cams/setups. Especially when it comes to cams they don't use.
This is the kind of sh!+ I want to know about BEFORE I buy one. Not AFTER. I don't have to wait til after I've tuned with one to know or understand these kinds of details.
Not taking anything away from the PV. I'm sure it's a fine tuner. But from everything Ive learned from reading and talking to tuners that have used both, the TTS is more capable.
Old Feb 11, 2021 | 11:50 AM
98hotrodfatboy's Avatar
98hotrodfatboy
For the general public that just want a good+ tune that don't understand all the glitter can adapt very easily to the PV.. It's not an issue about every thousandth of a second... It's about enjoying your ride and not spending 100 hours trying to figure it out... And yes some of us need the support of a shop like Fuel moto to feel confident about our ride...
Old Feb 11, 2021 | 12:40 PM
marcodarq's Avatar
marcodarq
Again, Gunner speaks without knowing what he is typing about.
while i do not disagree that the TTS is the more powerful/capable tuning tool, you are dead wrong about the crank tooth and knock capabilities of the PV. While yes, the " auto-tune" spark tuning capability in the PV doesn't work, the rest does, and works just fine. Get some real world experience!
Pauley want a cracker?
m
Old Feb 12, 2021 | 06:06 AM
98hotrodfatboy
m
He is getting very annoying... There have been several threads that he made controversial..
diesel6060
May 4, 2022 10:57 AM
Frans Pieterse
Screamin Eagle CVO Models
26
Aug 5, 2018 01:02 PM
T Man
Sep 3, 2016 10:27 AM
blueangel73
Apr 17, 2015 03:58 PM
HIOCTANE
14
Mar 29, 2015 11:34 AM
