Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
My apologies if this has been discussed before. New to the HD Forums.
Replaced the throttle cable and return because the throttle cable broke. Adjusted both new cables, bike idling high. The butterfly is completely closed when the throttle is released. Also have a check engine light, cleared code B1007 and there is still a check engine light. Thinking I should clean IAC and TPS. Any other recommendations???
