Ignition Switch Problem
Old Nov 19, 2005 | 08:49 PM
Motormedicus's Avatar
Motormedicus
Default Ignition Switch Problem
Greetings all. I did a couple of quick searches, and came up dry. I just had an incident with my 05 Ultra ignition. With the key in the unlock position, I moved the ignition block into the fork lock position. I was then unable to get it to turn back to the run position, until I inserted the barrel key, and tried to turn it even further counter clockwise, as if going past the unlock point. Hope that makes sense...
I was able to cycle the ignition a few times, and now it seems to be functioning properly. Just curious if any others have experienced the same thing, and what the outcome was of any repairs from the dealer. I will have it looked at the next time I take it in.
Thanks
Scott
Old Nov 20, 2005 | 11:37 AM
John TN's Avatar
John TN
Default RE: Ignition Switch Problem
See if this might be what you're looking for.
https://www.hdforums.com/m_168759/tm.htm
Old Nov 20, 2005 | 12:36 PM
Motormedicus
Hey John
I will have a dialog with Jack, but I think that my problem is a bit different. But thanks!!
Scott
danimal212
Oct 20, 2017 06:33 PM
dyna rider
Milwaukee Eight (M8)
Oct 30, 2016 11:21 AM
flhxmc
Feb 22, 2013 09:53 AM
superdog48
Feb 15, 2006 12:09 PM
jbriley3
Sep 3, 2005 02:55 PM
