2001 Heritage softail classic EFI (ecm fuse blown)
Old Sep 2, 2007 | 07:54 PM
kwhite's Avatar
kwhite
Stage I
Default 2001 Heritage softail classic EFI (ecm fuse blown)
2001 Heritage Softail Classic 12000 miles.
Hit the road this afternoon with the wife ,had ridden a couple hours earlier in the day,with no problems.
Was only 2 miles from home when the bike just quit,pulled over scratched my head pulled the seat off, ecm fuse was blown,took the spare fuse put it in ,turned the ignition switch, blew the fuse immediatly, put in another ,same thing....went home and got the trailer ....searched this forum and others ....nothing .
Interesting thing- the horn blows with a different sound...any thoughts?
I was due to ride with some friends in the morning in the N georgia mountains .........guess i'll be home doing honey-do's
Old Sep 3, 2007 | 06:26 PM
turbo54's Avatar
turbo54
Default RE: 2001 Heritage softail classic EFI (ecm fuse blown)
Have you got a pc 3 ? I think your bike is a Delphi EFI and that is a 15 amp fuse.
Old Aug 13, 2010 | 05:03 PM
digger51800's Avatar
digger51800
Stage I
did you find out what was doing it mine doing same thing and blowing fuel pump fuse 2
Old Aug 13, 2010 | 10:28 PM
donovann2o's Avatar
donovann2o
bare ground wire somewhere...start unplugging connectors and chase it down. grab a handful of fuses and a lot of patience. The ecm wire harness is a big one. If you can download wiring diagram that will help you out a lot!
Old Oct 29, 2021 | 03:05 AM
roach66's Avatar
roach66
Stage II
Default Ecm fuse blows as soon I turn my ignition on
I 2007 soffail I been been trying to figure out why the ecm fuse.keeps blowing when I turn on the ignition ive replaced both relays and unplug fuel pump and am going to check the tssm I can't get to the service codes some the odometer will be blank
Old Jun 15, 2023 | 11:05 AM
eplion63's Avatar
eplion63
Default ECM fuse continued?
Hey guys, anyone find the fix for this?
mine just started having same issue with PC3 plugged in - ECM fuse blows upon run switch. With or without fuel pump fuse & Starter relay plugged in.
Starts and runs with regular Factory plug in ECM. But runs poorly due to straight pipes and modified intake.
I have peeled back much of the protection on the PC3 wire harness and can find no bare or worn wires.
I believe I have read the PC3 uses power from a fuel injector source and perhaps that connection is going to ground somewhere and forcing the ECM to blow? Looking at the bundle of wires that flows to the ECM plug… again I can see nothing raw, worn, or exposed. Bike is FI 2005 deuce. PC3 been fine since I bought with bike in 2007.
GhostC6
Jun 25, 2019 03:25 PM
BigDog07
Jan 24, 2018 05:04 PM
butterballs
The Dyno Room
Mar 1, 2017 06:57 AM
Stuffa
Electrical/Lighting/Alarm
Jun 20, 2016 06:37 PM
marinedad1
Jun 1, 2010 09:36 PM
