t/max files
Old Nov 17, 2007 | 06:24 AM
rollonoff's Avatar
rollonoff
Default t/max files
Help,just installed t/max,got as far as load base map file,comes back saying no file found please try again,my bike is nearly standard 2007 fxstc doherty power pac filter,2.25 rush slipons,what is happening.
Old Nov 17, 2007 | 10:12 AM
SGDude's Avatar
SGDude
Default RE: t/max files
Did you open a basemap in SmartLink before you tried to write it? Don't know if you went through the process in the manual, but you have to select the one for your bike first.
Old Nov 17, 2007 | 10:28 AM
UltraKla$$ic's Avatar
UltraKla$$ic
Did you go to Tmax's http site and download all the maps after loading the program on your computer?
UltraKla$$ic
[sm=ummmmokay.gif]interesting.............double post with only 1 hit of the "post" button.[sm=outcold.gif]
Old Nov 17, 2007 | 12:43 PM
AustinRider's Avatar
AustinRider
ORIGINAL: UltraKla$$ic
Are there maps available on the Tmax site in addition to the one's that come with the software that comes with the Tmax w/Autotune unit? I couldn't find any on the the site. If there are, please post a url.
Thanks,
AR
Old Nov 17, 2007 | 01:26 PM
rollonoff's Avatar
rollonoff
thanks for the replies, i found the base map closest to my bike,then clicked load map file but it came back no file fouind or no match found,thats as far as i have been able to go, even tried stock base maps and still the same. cheers Tom UK.
Old Nov 17, 2007 | 01:44 PM
ajayrk's Avatar
ajayrk
After you load a map to the program you upload from the software to the ECM by clicking "file" and then select "write module map and settings". The map will then be transfered from the program to the TMax.
Old Nov 17, 2007 | 02:15 PM
SGDude's Avatar
SGDude
I can walk you though all the steps, but they are in the manual. If it's not making sense, reply or pm me and I'll go through it with you.
Old Nov 18, 2007 | 09:04 PM
SGDude's Avatar
SGDude
Let me know how it went.
wadecross
Aug 28, 2017 07:48 AM
cweiss
Mar 15, 2013 09:01 PM
HangFire
Sep 21, 2009 01:41 PM
oinker02
Feb 8, 2009 07:38 PM
2StrongHayn
Sep 18, 2007 11:10 AM
