Battery Removal & Smart Siren II
Old May 16, 2008 | 05:02 PM
Tab's Avatar
Tab
Default Battery Removal & Smart Siren II
Pardon my stupidity here guys but I need a bit of help. Just received my PC III from Fuel Moto so working on the installation. The 08 calls for removal of the battery so that you can route the ECM cable under the right side frame tube. Problem is I can't disconnect the battery without my Smart Siren going nuts. I tried unplugging the smart siren and it still goes nuts. Question is.... how the heck to I disable the Smart Siren while I remove the battery to reroute the ECM cable?
Can't find any info in my owners manual, service manual, or in the Smart Siren intructions that came with it.
Thanks,
Old May 16, 2008 | 05:26 PM
FireRescueFL's Avatar
FireRescueFL
Default RE: Battery Removal & Smart Siren II
I just had my battery disconnected a few hours ago. I left the siren hooked up. When you disconnect the battery terminals, the siren will let you know that it no longer has a power source and is running off it's reserve power. It sounds like the alarm is sounding but stops after a couple seconds.
---Chris
Old May 16, 2008 | 07:58 PM
Cruiser 1970's Avatar
Cruiser 1970
Turn the ignition switch on, then disconnect the negative battery cable. Now trun the ignition off. It works for me.
Old May 16, 2008 | 10:13 PM
Jim Dawson's Avatar
Jim Dawson
ORIGINAL: Gundog
That's how I do it too. I think I read it in the electrical manual.
Old May 17, 2008 | 04:30 AM
SK8ROD's Avatar
SK8ROD
i didnt remove my battery but then i have a Street Bob
albertasaurus
Oct 5, 2022 02:52 PM
Rocker_Dan
Dec 21, 2013 11:32 PM
JayOhh
Apr 17, 2013 12:02 PM
Vetter31
Screamin Eagle CVO Models
Mar 23, 2013 01:50 PM
donivan3
Jan 28, 2008 02:11 PM
