pc 111 error
Old Jun 15, 2008 | 07:54 PM
gamb's Avatar
gamb
Default pc 111 error
&nbsp\\;purchased from a member here, for a 2007 road king. tried 2- different laptops,every comport,only get sn no. and no devise error! any help will be appreciated! thanks&nbsp\\; gamb944@yahoo.com
Old Jun 17, 2008 | 06:42 PM
jeff194's Avatar
jeff194
Default RE: pc 111 error
It probably needs to be either hooked up to the 9 v adapter, or the engine needs to be running. But not both at the same time or you will set a code.
Old Jun 18, 2008 | 12:41 PM
gamb's Avatar
gamb
thanks jeff! the 9 volt did it!
Old Jun 18, 2008 | 12:45 PM
2008FLHP's Avatar
2008FLHP
ORIGINAL: jeff194
oooh oooh I've done that one!!!
Old Jun 18, 2008 | 05:36 PM
jeff194's Avatar
jeff194
Yeah, me too, also don't try to update your firmware with the engine running, I got a nice pucker factor on that one, lol. Use the 9 v.
Old Jun 21, 2008 | 10:25 AM
glens's Avatar
glens
Use a fresh 9V battery when flashing the unit. A brand new one will be unusable after about 20 minutes powering the Commander.
Old Jun 21, 2008 | 04:32 PM
iclick's Avatar
iclick
ORIGINAL: jeff194
Yeah, a real pucker factor, like a dead PCIII for about 15 min. in my case. Fortunately it revived and took the firmware upgrade. FWIW, setting 100% TP is best done by using the 9V battery and switching on the ignition, but not starting the bike. I've used this method numerous times with no problems, and is easier than having the engine running since you can hold the throttle at 100% 'til it settles. This only takes a few seconds, but is too long with the engine running.
Old Jun 21, 2008 | 04:39 PM
bikerbehaviorist's Avatar
bikerbehaviorist
iclick, you still need the motor at running temp when you do it this way? Also if I am changing maps I have to reset 0 and 100% TP each time right?
north texas harley
Oct 7, 2012 09:45 AM
Road king custom
Jul 1, 2012 08:41 PM
JCFLHRS07
Motorcycles For Sale
May 6, 2012 07:19 PM
oldtech
Feb 17, 2012 04:26 PM
oldtech
Feb 12, 2012 11:25 PM
