ABS lite
Old Nov 23, 2009 | 05:50 PM
gamb's Avatar
gamb
Smile ABS lite
ABS lite is on in tach display!any help on wiring diagram to cut it off would be appreciated,thanks.
Old Nov 23, 2009 | 08:52 PM
Shovelhead Bob's Avatar
Shovelhead Bob
The light is on because some fault has been detected....
Could be a bad wheel speed sensor, failed bearing, faulty ECU/HCU.....
The ONLY way to disable the light is to also disable certain other functions inside the tachometer...
Old Nov 24, 2009 | 04:08 AM
jkoch09ultra's Avatar
jkoch09ultra
Had the same on my 09 Ultra. Took it to the dealer and they replaced a wire under warranty.
Old Nov 24, 2009 | 06:23 AM
hrly_tech's Avatar
hrly_tech
that has been a big problem. a wire up by the steering head, coming from the front wheel speed sensor, isn't routed very good. and when just turning the steering it eventually makes a break in the wire. just check the two wires coming up from the speed sensor. and feel on the harness side of the connector for a break in the wire.
Old Nov 24, 2009 | 09:51 AM
gamb's Avatar
gamb
Smile ABS lite
i want to turn lite off! any idea? i want to cut or disconnect wire from tach or any other place(frame,ect.) to turn lite off! thanks
Old Nov 25, 2009 | 09:09 AM
Shovelhead Bob
Funny, why don't you just fix it correctly and have a fully functional ABS system...
Old Dec 2, 2009 | 08:02 AM
gamb's Avatar
gamb
Default abs lite
brakes work find. hd tech checked it out,said abs system find but could not turn lite off!
evo69
May 2, 2019 03:06 AM
Righty
Oct 4, 2018 09:26 AM
elwoodto
Apr 25, 2015 10:29 AM
Smokey Stover
May 5, 2014 03:39 PM
toothmansteveb
Apr 12, 2014 06:40 PM
