ABS module wiring harness plug
Old Apr 12, 2014 | 01:43 PM
toothmansteveb's Avatar
toothmansteveb
Default ABS module wiring harness plug
I'm trying to unplug the wiring harness from the ABS module to check the front sensor wire for a short.ABS light stays and the code is 1032 (front wheel sensor). The plug has a red locking clip that comes out part way but the plug will still not come lose. Dose this red locking clip have to be removed or am I missing something? 2009 Ultra.
Thanks for any help.
Old Apr 12, 2014 | 06:40 PM
ohioflhs's Avatar
ohioflhs
Just do yourself a favor and check for an open in the ABS sensor wire right at the front of the gas tank where it goes through the holder that attaches it to the frame. I did a lot of troubleshooting before I finally believed the guys on this forum that that is where the problem is. You can't even see that it is broken. The insulation was fine, just the wire inside was broken.
evo69
May 2, 2019 03:06 AM
Righty
Oct 4, 2018 09:26 AM
mkekid
Apr 26, 2015 06:06 PM
elwoodto
Apr 25, 2015 10:29 AM
twocoltbob
Oct 29, 2010 03:12 PM
