I have an 08' ultra w/ABS and lately the indicator light that usually flashes and then disappears after I take off, is now staying illuminated. Anybody know if it's just a sensor or had this same issue? Thanks for any advice.
There is a design defect in the wiring loom right where the wires branch off to go down to the sensors in the neck. Sensor wire breaks there. No continuity with the sensor and the ABS module. The dealer will try to get you to replace the sensor first (don't ask how I know), then will take the time to troubleshoot the loom. 08 Ultra here. I'd start there. They know about this issue.
Much appreciated rpeters282, thank you for the response. When I go in for my next service, I'll ask them about it and see what kind of fix they'll recommend to me.
I am having the same issue on my 08 ultra. it is intermittent. other words it doesn't always do it and I can reset it by turning the switch of and back on.
