Broken ABS sensor wire 2008 FLHT
Old May 28, 2018 | 07:44 PM
Righty's Avatar
Righty
Stage I
Default Broken ABS sensor wire 2008 FLHT
near the connector front fairing area --is this a common problem; does the ABS light come on and stay on or will it vary? What is the fix and how long has HD known this?
Old May 29, 2018 | 07:41 AM
ohioflhs's Avatar
ohioflhs
Yes. It is common. It is usually broken near the cable tie by the frame neck. Find the right color wire and pull the wire apart a little bit. The insulation will stretch where the wire is broken. Just splice it there. I removed the cable tie. Probably should put another one on it a little looser.
Old Oct 3, 2018 | 10:56 PM
ronbeejer's Avatar
ronbeejer
This probably isn't the right place to post but...
I have the same problem. One of the wires broke near the cable tie and has left me with no ABS. I've located the break but it's pretty damn close to the connector which would make a splice damn near impossible.
Question: Can I use a different type of connector instead of the Harley OEM style connector? Or do I have to go to the dealer and buy their product?
Sorry, my electrical knowledge is challenged to put it mildly.
Thanks!
Old Oct 4, 2018 | 02:41 AM
markwolula's Avatar
markwolula
Thanks!
I had the abs wire break under the left side, close by the connector.....
In your situation , (not enough wire to splice close to the connector),, I would do away with the connector all together.....
Make sure you find the correct wires that go together, (there are two that go to the sensor).. Do one pair at a time so you don't mess it up...
Cut wires at the end of connectors,,, splice/connect the correct wires together ,,, Turn ignition ON, and check that abs light is flashing , not on solid ,,, cable tie wires in safe location under left side ,,, Go for ride and check if abs light goes out ,,, Find a quiet road and hit brakes to check that abs is activating …. If so,, go and have a beer …..
Old Oct 4, 2018 | 09:26 AM
ORradtech's Avatar
ORradtech
Thanks!
Personally I'd use a new stock connector. I'd also add a couple of inches of extra wire when I did. That way you don't create future problems if the sensor needs replaced and you help prevent the problem again by adding some slack to the wiring.
You could go to a different connector but then if repairs are needed later you'd have to rework the new wiring as well.
You could also do as suggested and eliminate the connector but I don't like that for 3 reasons.
1, as above, any repairs will have to rework wiring
2, soldering creates brittle wiring
3, you're effectively shortening the wiring by an inch or more.
elwoodto
Apr 25, 2015 10:29 AM
toothmansteveb
Apr 12, 2014 06:40 PM
shore
May 1, 2013 02:47 PM
Bandit111
Aug 8, 2011 10:25 AM
twocoltbob
Oct 29, 2010 03:12 PM
