General electrical question
Symptoms...
Sometimes the starter hesitates and I get a little compression pop before it starts. Other times it turns over very quickly and starts instantly
I have a fluctuating voltmeter. Especially when I grab the front brake and use the blinkers. It jumps all over the place.
2 days ago I went out on a 150 mile ride with no problems at all. Later that night I went to get coffee and my radio stopped responding. It was stuck on and none of the controls worked. I then got a terrible noise when I grabbed the front brake. Then a loud buzz, the tach jumped to 8K, the voltmeter dropped to 2v, the bike almost stalled and the radio when dark.
Same thing happened about 30 minutes later. The only thing I did different at night was I had my spotlights and my side bag lights on.
I took the bike apart and noticed my 5 amp POD fuse was blown and the 5 amp power fuse on my radio is blown. I replaced the fuses and the radio is back to working fine. I then replaced the 4 circuit breakers under the fairing. I started the bike and turned every accessory on and felt the wires to the circuit breakers. The single red wire on the breaker to the left (when facing the bike) with the 3 red wires on it was hot. Not burning hot but certainly very warm.
So.. on to the general question...
Would bad battery cables cause these problems? The cables on my bike look to be original.They are date coded 70033-89. I removed them and peeled back some of the jacket and they are green/white with oxidation where they are crimped to the lugs. The copper gets better as you peel back the jacket.
if it is your VR you'll want to figure it out quick and replace it because when it kicks out it can take a lot with it. Easier to replace just that
and why not just replace your battery cables while you're at it
Good luck, electrical problems can be a real Biatch!
RD
RD
When I first start it, it reads about 14v constant
After it warms up it reads about 12.5v
With the headlight on it reads about 11.5v-12v
If I put either of the blinkers on it fluctuates between 8v and 11v
If I grab the front brake it drops to 6v-8v
If I have one of the blinkers on and the front brake is grabbed it drops to 2v-4v
Keep in mind, the actual voltage at the battery is a consistant 12.7v at idle and 14.1v at 2500rpms. I hooked up a Fluke meter to it to test it.
The reason the voltage drops so much when grabbing the front brake is that its connected to the anti-dive solenoid which draws a fair amount of current.
I went through the entire bike again last night and I added an additional ground for my voltage regulator. I am thinking the problems I am having are due to my original 20 year old battery cables. Although they looked good on the outside, they were not good on the inside.
