Headlight dimming/volt meter dropping
Old Sep 22, 2008 | 05:47 AM
monkyman's Avatar
monkyman
Hmm, I just noticed this same problem with my Road King the last couple of mournings. I only notice it at highway speeds, headlight gets bright, then dims, gets bright, then dims. I'm going to try to take a look at it tonight when I get home, but what have the rest of you found this to be? was it your regualtor? Bad Ground? Stator?
Old Sep 24, 2008 | 04:20 AM
monkyman's Avatar
monkyman
Well ok, problem solved. I did a voltage drop from the battery terminals to the cables and found that with just the key on, I was looseing .5 volts from the positive connection. 1 full volt while cranking. Negative side was "0" during any test. I took the positive terminal off, cleaned up the connections, rechecked "0" loss. Drove to work the last two mournings and the headlight stayed bright. Hope this can help someone else.
MDT
Electrical/Lighting/Alarm
Jun 1, 2016 09:23 PM
BOSOXFan
Nov 8, 2015 07:14 PM
dirtdobber
Screamin Eagle CVO Models
Apr 25, 2015 08:00 PM
Houlie
May 21, 2013 10:15 AM
klyde9876
EVO
Aug 11, 2012 05:10 PM
