Speedometer problem
Old Oct 8, 2006 | 09:38 PM
hd2000's Avatar
hd2000
Default Speedometer problem
Lately when i turn the ignition on on the bike the mileage won't show up. Another thing that i noticed is that when you get on it hard the needle will jump all the way to 120 and then sweep back to 0. The bike is a 2000 wide glide.
Old Oct 8, 2006 | 10:03 PM
FLSTC's Avatar
FLSTC
Default RE: Speedometer problem
May be as simple as a loose wire, check your connections for the speedo and verify there's corresion in the connector. Check the ground terminal for this circuit, your manual should help you locate it.
Old Oct 9, 2006 | 03:13 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Is the bike overcharging? Have you popped any bulbs?
Old Oct 9, 2006 | 02:45 PM
hd2000's Avatar
hd2000
I haven't poped any bulbs. Its seems like it hust started after i changed my pipes.
jcboof
Jun 29, 2020 01:41 PM
ttocs7230
Engine Mechanical Topics
Aug 27, 2016 12:26 PM
ChargingRhino
Jun 20, 2014 09:54 AM
PktChg
Jul 26, 2012 08:51 AM
hd2000
Oct 8, 2006 11:23 PM
