Power Vision Information Thread
Old Feb 15, 2012 | 07:00 PM
  #1761
Teardrop's Avatar
Teardrop
Got it.. thanks!
Old Feb 16, 2012 | 08:49 PM
  #1762
RLE's Avatar
RLE
Im looking over the first log I did. I notice that out of nowhere, under no hard acceleration or deceleration, my afr drops from the usual 14.5-14.6 down to 12-1. The only other value I see that changes is kpa drops considerably at the exact same times the afr ratio drops. Why would this be?
I am running stock o2 sensors and did the log off of Jamie at fuel moto's map; one that runs great.
What does kpa even mean? Some sort of manifold pressure?
Old Feb 16, 2012 | 09:01 PM
  #1763
whittlebeast's Avatar
whittlebeast
KPA is pressure in the intake. 104 KPA is as much pressure in the intake as is possible. 0 KPA implies no air it the intake at all.
Note:This assumes you are not running a turbocharger.
Beast
Old Feb 16, 2012 | 09:28 PM
  #1764
RLE's Avatar
RLE
Beast
Ok. So what, while at a steady rpm, would cause intake pressure to drop drastically. From say, 60 kpa, down to 20. There does not appear to be any problem with my intake or air cleaner.
Im assuming the fact that it drops down to 12-1 afr it puts itself into open loop for what is probably a second or 2, and then back into closed loop. With no real trace of why.
Old Feb 16, 2012 | 11:21 PM
  #1765
whittlebeast
Did you get it in a data log you can post?
Beast
Old Feb 17, 2012 | 06:08 AM
  #1766
RLE's Avatar
RLE
Ya, f*** if I know how to post it though. Ill try to figure it out later and post it. Sometimes I hate computers.
Old Feb 17, 2012 | 07:20 AM
  #1767
lhgdale's Avatar
lhgdale
Click the link in my sig to get a basic PV tuning guide that I put together. It is a simple set of instructions to get you going. Come back here to ask questions and we will be glad to help. You probably noticed that a lot of the 176 pages are helping one forum member or another.
+1 This guide helped me out tremendously!! Great write up..
I also asked a question a few pages back when the spark plug, knock sensor questions were being addressed. Fuelmoto recommends the stock plugs but would upgrading to the SE plugs cause any problems with the sensors? Thanks
Old Feb 17, 2012 | 06:09 PM
  #1768
Yardstick's Avatar
Yardstick
Steady state cruise and a sudden drop in KPA would tell me that the map sensor either is going out or there may be a ground problem somewhere. AFR going to 12.1 and then back will not drop you to open loop...ECU will remain in closed loop until the AFR table entry drops below 14.6.
If you were to remain in 12.6 due to map problem...bike will go into limp home mode....don't ask me how I know all this....had a problem with an 2011. Different cause which neither DJ nor HD could figure out.
But, the ultimate answer to the problem that I had was to put the ECU into open loop so it would ignore O2 sensor input. But, diagostic codes were pinpointing MAP sensor problems.
Had to experiment to find the bottom line problem by experimentation....after MAP was replaced by dealer.
If the log shows a sudden drop in the KPA to zero and then a jump back to a normal reading, I would suspect wiring corrosion or ground problem first.
Old Feb 17, 2012 | 07:06 PM
  #1769
mtclassic's Avatar
mtclassic
maybe you came to a hill. that increases kpa and would increase fuel demand while keeping the same speed.
Old Feb 17, 2012 | 08:38 PM
  #1770
eddiepoindexter's Avatar
eddiepoindexter
Question Stupid question???
OK, so I've been running logs, and I have a question. The MAP I'm using has everything from 80 KPa and down, and 4000 RPM and down changed to 0.981 Lambda.
Should I be changing any other cells?
I'm using the NB o2 sensors.
: EP
