Power Vision Information Thread
I was looking at the tunes in Winpv and see where now I have both TPS and MAP VE tables. This is new to me as my 08 only had TPS VE tables in it's tunes. In comparing MAP VE tables to TPS VE tables I see the numbers are very different. This has me confused. Why do I need to see the tables in both MAP and TPS? What is the top scale numbers on the MAP VE table? 10 through 100 of what? What does the 10 represent? Not 10% of throttle position.
I don't see the Closed Loop Bias table either. Did that go away?
Help me Stalljim61........LOL. I am lost again! This has changed a lot since I did my 08 and I almost feel like I am starting over.
You can twist the throttle from 5% throttle to 20% and the Map will jump all the way to 100% load then back off to 50% load as soon as the bike starts unloading.
The closed loop bias is now called closed loop bias lambda range. It is already set and no need to change that I have found.
I have my PV mounted and watch Throttle position and Map Kpa load and you will quickly learn the comparison.
If you want I will send you two maps with each set up. One will run TPS and the other will run MAP. Just PM me with your email address and what is on your bike and info as to what your bike is. I have a 14 limited and PV2 also. Have had three different exhaust on it. I mostly run the TPS, but can run either one.
Just noticed where you are. You are only 100 miles west as I am in Monroe.
I would love to see your tunes, if only to compare. I will send my email in an PM.
I come over to Monroe for the dealership I work for part time every so often.
The way this new 2015 limited runs off the showroom floor is so good I am not sure if I need to do much. I am adding the SE AC and SuperTrapp Fatshots (for sound mostly). I just want to get the VE's dialed in and I will probably call it good.
Sent maps little while ago. We are having the La Hog Rally in West Monroe this year, hope to see you then.
http://www.youtube.com/watch?v=Ycm4-KNGz14#t=165
Tomorrow I put on my Krome Werks +2 bars. That will probably be all that gets done tomorrow.
I did data logs today and looked them over excel. I had no knock events on the front and 2* or less on the rear so timing seems to be pretty good for now. I had the ET up on the gauges and it ranged from 250 - 270 all day. I was running between 60 and 75 most of the day. That seemed a little high to me. When I checked the oil temp it was only 235 which is pretty much perfect.
Now that I have the AC on the bike I will be starting over dialing in the VE's. That is if the weather will cooperate. I am pretty happy with the way it runs now as it is. It doesn't have the down low grunt my highly upgraded 08 had, but from 3000 rpm on it sure does. I am hoping the AC will help with the down low grunt. Time will tell.
When I was getting the Log files off the PV I saw it had two PVV files on it as well. I don't remember seeing PVV files when I got the logs off of it two years ago when I was tuning my 08. Were they always on the PV after a AT run? I copied them to my PC and when I clicked on one it opened LT, but it didn't populate it. I am a little confused on that.
Well one step at a time. Tomorrow the bars.
I'm about to put a 68t pulley on, currently have a 66t pulley and a 2146 value for the pulses per KM. I'm unclear on if I need to increase or decrease the pulse value when I go to the 68t pulley. I know I'll have to play with it some, but I have no clue if more or less pulses will get my speedometer reading closer to correct. I know that just going to the 68t pulley is going to make my speedometer read faster than I am actually going.
Or in the off chance that anybody has a 103/ 6spd and a 32t drive pulley and a 68t rear and have adjusted for it I'll gladly take your value for a starting point!
Rear cylinder -11 to +4.4.
Second AT Delta to 1st AT map got -6 to +5.5 front and -7.6 to +4.4 on the rear.
So the numbers are getting better with each AT, but the fact that they are going down so much from the original FM map surprises me. The bike is running pretty strong and when I looked at the logs I only had knock events when I really pounded on it one time and even then it wasn't high enough to not be adjusted for by the map.
I will do some more tomorrow to see if the VE's get dialed in. I know I am looking for no more than a 5% change in the VE's. Is that either way, + or -? In other words +5 to -5 in delta. I am getting old and can't remember since I did my last bike.
