Power Vision Information Thread
TTS is adding more and more for the 'pro' level guys and has way more features. TTS IS way harder to learn and use. See it through, though, and the end results are better.
I feel the PV is a really nice tool for beginners on HDF. Don't get me wrong on that. LOts of base maps and those guys get close with a half hour ride. Something to be really said for that as most of these guys are dealing with Stage 1s and maybe cams.
TTS takes some work, as you know. Tune WILL be better in the long run with the tools TTS has as to the NON tools PV has.
If you want an easy way to tune quite decently, use PV, if you want all there can be, use TTS.
Your choice.
Exactly what tuning capability do you believe exists in TTS that isn't available in the PowerVision and the accompanying WinPV software? Yes, there are limitations on the PV itself that essentially reduce tuning to the most convenient features that are likely to be used by a rider while on the road. But with the WinPV software nearly every imagineable variable can also be used to make fine-tune adjustments before loading a file back onto the PV for flashing to the bike's ECU.
I would argue that the PV is equally suitable for the very advanced tuner as it is for the novice. If an inexperienced rider wants to only use the tuning capabilities directly on the PV unit itself, then the approach is simplified and complete but limited to the most commonly tuned components. If the user wants to fine tune a map with deep adjustments within the file, then the WinPV software can be used by attaching the PV to a laptop and using WinPV to make those adjustments.
In either case, no laptop ever needs to be taken on the bike to conduct tuning with either the PV or WinPV. Just collect the logging data on the PV while riding and "simple" tune on-the-road with the PV or bring the data back home and "complex" tune using WinPV on a laptop. Best of both worlds if you ask me.
1) Keep autotuning with lots of variable data under different loads in the region you're having knock events. Check after 3-4 autotunes to see if the knock events have been eliminated.
2) Change your autotune settings to include spark adjustment. The PV can reduce spark based on knock events (however it can only reduce spark adv, if cannot increase spark adv).
My recommendation would be to run 3-4, 20-30minutes autotune runs and then recheck the knock events. If they still exist, then move to step 2.
Look at data? HAHA! Yup you sure can gather a bunch on that flash drive in the box, where TTS can save like 30 channels for hours on end. The difference IS the PC. It is ALL give and take.
Quit being an *** anyways, didn't I say the PV was a decent tool? There ARE differences and until YOU have tried out a bunch a different methods, quit doing the 'money effect' thing and think that YOU bought it, it must be the greatest. There is NO greatest, all things have advantages and disadvantages.... even tuners. I have just went thru this myself, until I looked at things logically. I, me, just recently quit being an *** about all of this myself. I was a for REAL *** about it, too.
I was talking about a wild build that one needs to 'sniff' to get it right. NO closed loop at all. WIth TTS, I can still use things LIKE the cam tool, the baro setting, use the timing tools and NEVER touch the VEs using the tuner. SO, yes, on a crazy build, I WOULD go with the TTS. ANd that would be BECAUSE of the PC not the lack of it. Tuning IS data. AT some point, one NEEDS data to tune with. Flash drive does NOT cut it when ease of use isn't the question, but diagnostics are. I was talking to a member that has a DTT wego, etc. He HAS to lug a PC with him for best results.
Lastly, how many bikes, besides your own have YOU tuned with PV? I haven't tuned ANY, (I HAVE played with one, but NOT a complete tune). yet I recommend it extensively. Why? Because I like it and will own one soon. You with YOUR money, will you go in turn and buy a TTS? NO, of course not. You have NOTHING to compare it to. Keep drinking the Jamie Kool Aide. And remember THIS... TTS, Jamie, DJ... ALL of them are out for ONE friggin thing... get in OUR wallets. It is up to US, members here, to try all things and report back. NOT get wedded to an idea or a product and call it 'done'. You own ONE bike and have 'tuned' that one bike. Have you even played around with a TTS? How then can you even know its capabilities. Kool Aide tastes like ***. I have tasted it plenty, no more tho.
Besides... why is this an issue? I LOVE the PV and recommend to almost all members. But when a member comes on with a big build... I get slammed? It IS about the PC in the end. This isn't some little 30 minute ride bike to gather VE tables.
- Baro correction - nope but that's already built into the bike's ECM so if you're running closed loop why should it be fussed with?
- Spark Gain at idle - yep
- Auto tune timing - yep
- Cam tooth adjustment - nope
- Laptop backback - Nope - no need
- Lockdown of the bike's ECM so that even a dealer can't access it - Nope - that's a unique feature of TTS alone
You can get equal results with SEPST, TTS or PV. Just comes down to what you're most comfortable using to get solid results. The question is how much is it gonna cost and how difficult is it for the average guy to run. In the future something else will come along and make them all obselete. In the interim, any software that locks up the bike's ECU from being used with any other tuning software (TTS) or requires attaching a laptop to the bike (TTS & SEPST) can see the horizon of obselence not too far in the future.
The PV addresses all but the most exotic build tuning needs in my opinion and I wouldn't go back to a standalone tuner. But that's just the opinion of one guy with a pretty good familiarity with the different tuning products so take it with a grain of salt. Ultimately the marketplace will decide. And I think it already has.
What is the difference between Autotune and the log tuner? Are there different scenarios where one is better than the other or are they basically the sane thing?
Any suggestions on where I could read up on this stuff? I haven't gotten my head wrapped around how all of these variables relate to each other and how they affect things like knock and MPG. This all started cause my MPG is usually around 32 to 35 and that's with 60%+ freeway miles.
Before you change your spark settings its best to see if the autotune will eliminate the knock events. Reducing spark generally reduces performance but if the spark is so advanced that it causes a knock event then you'll lose the performance anyway since the knock sensor will reduce the spark advance to prevent the knock event.
What you're seeking in the load areas of the map is optimized VEs first, followed by as much spark advance as the engine will take without creating a knock event.
Use autotune first. After several rides, autotune will adjust the VEs and generally the knock will be eliminated OR if its a significant knock event, you'll need to datalog after the autotuning and then manually reduce the spark in the region where the knock is occurring.
If you started with a suitable PV map for your bike's engine there really should be no need to manually reduce the spark advance unless you live at a particularly high altitude or find yourself running really crappy 89 or less octane fuel.
