Power Vision Information Thread
Old May 18, 2011 | 07:54 AM
  #401
GoPro Steevo's Avatar
GoPro Steevo
Originally Posted by CoastlineAmps
Just ordered one for my 2009 FLHP. Any pointers or tips prior to installation?
For the cleanest installation, take off the seat and gas tank, run the wire inside the main wiring harness. Finish it off with a RAM mount, it will look real sharp!
Old May 18, 2011 | 09:38 AM
  #402
TRIGLIDEMIKE's Avatar
TRIGLIDEMIKE
Stage III
Default Question On EITMS Setting In WINPV
I have had my Power Vision for a couple of months now and really like it. Purchased from Fuel Moto and they preloaded a map for my '11 Triglide. Have had some pining issues that Jamie has been working on, but I think we are close to having that resolved. Anyway, I was just looking at the maps from Jamie and the stock map in WINPV and noticed that they all have the EITMS set to 0. If I understand correctly that setting disables the EITMS. The thing that puzzles me is that even the saved stock setting has 0 but I know the EITMS was working when I installed the PV because it was always kicking in. I don't know if I need to change this to a 1, but would like to have this feature active. I just don't know why the stock map would be 0 but it was working anyway.
Old May 18, 2011 | 12:18 PM
  #403
hornhonker's Avatar
hornhonker
Yes, change it to 1
Old May 18, 2011 | 12:45 PM
  #404
Cheezyrider's Avatar
Cheezyrider
I just went to the Power Vision and I like many of the functions and am waiting for the new functions in the software from Dynojet. EITMS in my stock map was 0 and in the map from Jamie is a 1.
Old May 19, 2011 | 09:59 AM
  #405
Sam2010's Avatar
Sam2010
What is it like when the EITMS kick in? My bike has done some intermittent funny idle I was wondering that was the problem. I have not been in any temps higher than 67. Bike was pinging and was getting a stumble off idle and roll on throttle around 2k rpm. I am open for tune suggestions before I bother Fuel Moto. I know for sure I am turning off the EITMS and see if thats my weird idle. Its not hot here if its kicking in I am surprised.
Old May 19, 2011 | 02:20 PM
  #406
papifun's Avatar
papifun
SAM - to begin - im reading this thread since i still havent connected my PV due to waiting to do my stage 1 and exhaust...
Is your EITMS selected on using the Harley way ? Meaning.... if you roll the throttle clockwise till it dont go anymore - the Cruise light symbol will light up on the Speedo gauge.. if its green then its activated.. if its Amber color, then its off.. if you hold it there it will change from current selection to on (green) or off (amber).. I dont know if the PV overrides the stock EITMS setting if selected via the throttle way.... if u can let me know or anyone else, would be great to post...
When the EITMS kicks in, you will feel a different shake of the motor and sound like a putt-putt .. like air is pushing... if you blip the throttle when in EITMS, it feels like engine will cut off or stumble - this activates the cylinder again to allow fuel to flow to it.. if u wait a few seconds and engine is still hot, it will kick into EITMS again..... i dont blip it anymore when in EITMS like my 2008 when i start off.. i release clutch and then throttle.. it seems to be smoother and no enging stumble anymore.. my bike is still all stock.. i had issue with 2008 when i had PCV and EITMS would kick in.. it would stall and puff of smoke out of AC.. Jamie sent a new map and then all was ok...
hope this helps a little.. i dont know how many post the EITMS never kicks in with a tuner and upgraded Exhaust.. mine always did and i dont live in 100 degree weather.. im lucky if we get to 80's.. but its humid here for 2 months.. thats how long our summer is...
ride safe...
Old May 19, 2011 | 05:46 PM
  #407
Sam2010's Avatar
Sam2010
The stumble off idle you describe is exact. I know the fuel moto map has it activated I am going to disable it. 67 was the high outside why would it kick in bike seems cooler and I mean way cooler than it did with stage one. I did notice these EFI bikes do not like throttle blips. No time to play off to work but going to take the bike.
Old May 20, 2011 | 07:22 AM
  #408
FX4's Avatar
FX4
iclick what a great thread. I haven't read this since it was only four or five pages long. Spent all night catching up. Between you and Jamie it completely makes it worth tinkering with this thing.
I do agree with you about DJ needing to develop a how to tune your bike from scratch instructions similar to TTS. Any progress on that front?
Old May 20, 2011 | 07:32 AM
  #409
CoastlineAmps's Avatar
CoastlineAmps
Dave,
So to be straight. I should wait to turn in my ECM only untill I get my upgrades installed on the bike? So far I am completely stock and looking to do small upgrades over time.
Old May 20, 2011 | 12:51 PM
  #410
iclick's Avatar
iclick
Originally Posted by Linville Lion
Not sure if this is a good place for this question but I am looking for the thoughts of those that have purchased a PV. I have a 2011 FLHTC (Electra-Glide Classic). It has run great since day one. I did a Stage II with 103, SE Air Filter and 255 cams. It has the HD ECM download for this build. The exhaust system is stock. It now runs even better. I normally use 87 octane gas here in western NC and never have any pinging or decel popping. Now, it has not been very warm. The highest ambient air temperature has not been over 85 degrees, yet. I have the 2011 oil cooler and the oil temperature has not been above 225 deg F.
The dilemma is that the bike is working great and it does not seem like anything needs fixed. What am I missing? Have there been improvements with the 2011s that make them better than prior model year bikes? I am perplexed. I would love to have a PV but getting one just to adjust the speedometer seems extreme.
I am looking for feedback. Thanks.
Your bike would benefit greatly from a tuner, AC, and upgraded exhaust system, including a header pipe to eliminate the cat. The stock AC and exhaust is really taxing the performance of your Stage II upgrade. Unless you really like to tweak and want to delve into the workings of the ECM, I would buy a PCV Power Package from Fuel Moto. This would include Jackpot mufflers, AC, and a tuner. The tuner could be a PCV or PV, and I suggest a PCV only because it is a simple plug-and-play proposition, yet can still offer many useful tuning features if you want to use them. You can even add Auto-Tune if you want, but that isn't necessary for most riders, IMO.
PV would be a good choice too, and if you chose that tuner you would still have a good tune installed for your bike, just as you would with a PCV. The difference is price ($200 or more), and the PV will give you a useful module that can be mounted on the bike to provide useful data like engine temp, MPG (avg. and instant), fuel-used, and many more.
Call Fuel Moto and ask for advice, as they won't oversell you.
