Power Vision Information Thread
tdkkart..... Yes i understand i can bug Jamie for life but i would like to be able to not have to run back to them with a million questions and a million times. I was just trying to see if others have felt this way also. the bike in no way runs bad. It still is smoothe after tuning runs....just seems to be detuned from what fuelmoto has sent me as a base map.
I have loaded the fuelmoto map in and confirmed that it has more get up and go on wide open throttle runs. So that is how i am where im at.
When i compare the AT runs to the fuelmoto map i see that the autotune is trying to take too much fuel from an area that i think it should not. It is also adding fuel on the rear VE table in the low load area. What im going to try next ( probably a weird thing to do ) is to take fuelmotos base map......take my auto tune runs cells that it increased the VE valuse and fuse them together. What i can hope for is a smoothe running snappy tune. What i will get....who knows. I dont see a problem in doing this. It should not hurt the bike but it may not be a good running tune. I will try this first. if i cant get the bike to run the way i think it should....then ill call fuelmoto.Im trying every angel i can think of and using all the info i can from this thread. Thoes poor guys are so busy they dont need to hear my crying untill i have tryed everything i can possiably think of. They have been great and have sold me some great products.
Thanks to anyone here that has an opnion. Im open to any experance or opnions you are all willing to toss at me. Ill try MOST anything once...lol
I'm not sure what you're running or your current set-up, but have you changed the exhaust system? The only time I've seen problems like this is when the O2 sensors are reversed, or the O2 sensor bungs don't allow the sensors to read properly (or possibly a bad O2 sensor).
What year/model bike are you riding?, and what exhaust are u running?
Something's not right.
I know I didn't explain the whole process, but hopefully you get the gist of it.
You want the entire tip in the exhaust flow.
You want the sensor parallel or a few degrees upwards. This keeps condensation from building up in the sensor and destroying it.
I believe you want the sensors within 6" of the collector on a 2 into 1.
Tthis is what I can remember from the last time I went looking for the same answers so you'll need to confirm.
i am not educated on this subject but i would/could easily be convinced with this line of reasoning.
the reason..... i have a habit of placing my hand at the exhaust on different bikes and some pipes really pull in between pushes, kinda like a plunger is being moved in and out.
that and (i think) i could see it on my tuning runs with my last exhaust.
but again, i am not educated on this subject.
Delta....Got it. i have seen this method used before. i have not een the log tuner software but i have read the post early on in this thread and tey did a very good explaination of it. So you make perfect sence as to what ya did. Thanks so much.
nhrider.... yes i would have agreed with you if i had not seen reversed O2 sensors first hand. my friend purchased a 2010 roag glide from seacoast harley and had issues right off the bat. that is what we found was reversed O2 sensors. So i know exactly what happens with that. mine are ok.
After 4 runs it is now where i thought it should be.Now my bike is starting to run good. It is almost like mine seemed to be very slow in VE correcting. What worked for me was my last run i put my wife on with me. Did a tuning run 2 up and the VE seemed to make a leap in the right direction. trust me i looked at everything.....2x.... i thought for sure i did something wrong. I bought a service man. and read it so much i think i was dizzy.
just to answer your question though....my ride is a 2012 street glide. it was stock. Meaning i did not have the dealer do anything to it ( im not a screamin eagle fan ) but clean it. I got the fuelmoto 2-1-2,jackpot 4inch,fuelmoto A/C and the powervision. Did i think this would make my bike a indy racer? No i just know i rode it stock for a bit when i got it and it was a sewing machine. My first AT run was ok. 2nd is where i started getting the idea im going backwards. 3rd....minor improvement....now after the 4th.....bing....there it is.
Im gonna do another run today. weather looks good and my roadglide friend is about to start AT on his bike. He and i did that wounded vets ride out of Boston harley yesterday and right at the end his bike shut down. Like it was vapor locked and it was hot....very hot. mine was hotter than it should have been also.So i will have to figure that out. he is running a base map from fuelmoto but never did any tuning.So....today we are gonna try to get him a step in the right direction.
a couple more runs on my bike and i think i will be ready to do some logging and look at the timing. Thanks to everyone that answered my questions. I think this forum is great. it opened up new ideas and kept me from driving my bike off the pier...
delta....yes sir i did change it. my map it was set to 500 as well. i lowered it to 295/ I have always thought the EITMS comes on too much. so i tried upping it a bit. I might have to lower it down a bit. i just thought it was kind of a close on off because my off i believe was set to something like 274. After yesterday i found out it does not bring the temp down much when it kicks in so i think i will bring it down to were you sugested. After a couple more VE runs i might try taking my A/F from 14.4 to like 14.2 and see how much that help. i don thave high hopes as i have seen a few posts here that say it would only lower temps by like 5 to 10 deg. but it is worth a shot.
I was comparing this tune to some auto tune runs I have done in the past.
I noticed that when I loaded the compare file that the EITMS on Temperature was different between the 2. I have not changed this. The copy of the tune that I loaded back out of the EMC shows an on temp of 590F the original tune was 284F.
I also noticed there were changes in the air fuel table and the VE tables. I did nothing to alter any of these. The AFR table had changes +- .001 not a big deal. The VE tables show changes of +.2 to -.2 not a big deal.
I have not done any AutoTune runs at all when this map was loaded.
This morning I did a test I took the original tune from Fuel Moto that has the EITMS on temp at 284F and loaded it back to the EMC. Cleared learned fuel offsets and did the power cycle on the bike. Then I loaded a copy of the tune back to the PV and brought it in and attached it to the computer and loaded it into the WinPV software. I then compared it to the original file I just downloaded and sure enough the EITMS on temp had changed to 590F and the VE tables showed deltas of +.2 to -.2 and the AFR table had changes of +-.001
Has anyone else seen this? If the values are actually being changed that is not good and what else could it be changing. Is it that there is an issue when they read the tune back? Bottom line is if you read it out and do not check your EITMS temp could be set to 590F this is a big problem. I checked and did not see any place in the Quick to change the EITMS setting that might show it is corret on the EMC
I will be calling Dyno Jet on Monday and seeing what they say.
Right know I am not happy with the fact that changes are being made to a tune just by reading it back from the EMC to the Power Vision. And that it is changing a safety feature to a very unsafe level.
Hopefully this is just on my PV and not an issue for everyone. And yes all my software/firmware is up to date.
I am curious if anyone else has ever noticed things like this
Disclaimer - In my opinion.
