Power Vision Information Thread
if i remember right i thought there was some back and forthe about using the stock plugs will get you a better tune vrs say NGK.
Anyone ever run into problems with NGK or any other plugs being too hot or for some other reason not to use them?
Same here i have never had a proble wth the NGK i use. I think this is a myth but figured id ask to see if people did actually have problems.
something else always on my mind is.....if AT sets the A/Fto 14.6 across the board.....and the stock sensors read that....you will et data even in te high rpm and kpa areas. i did. many still say you dont or cant tune the upper kp or rpm wihout wide band sensors. i dont agree.
I emailed dyno jet asking what is charge dillution effect and how do i use it. Dyno jet claims it is effective in the upper range. I have seen posts here say it is only effective until 60 kpa. The 60 kpa limit seems to be right out of the TTS manual. Dyno jet does also say that most dont ever use it and they have good running tunes.
So does the PV CDE adjust the upper range like dynojet claims or is it only effective up to the 60 kpa range?
As far as CDE. It diminishes to almost nothing at 60ish so above that the affect is low. It may show a measurable change, however, in my opinion, it's uselss up there. By the time you affected a change in a VE that high you would have jacked the VE's up so high in the lower kPa cells that you'd be screwed in that section. Remember, the affect diminishes out to the right. So a small change at 60 also makes a bigger change as you head left in the rpm row. I wouldn't even attempt to play with CDE unless I had something crazy happening in the lower map areas. You also need to consider how the effect changes the flow of the VE's as you look up and down the columns. You may fix a bump or valley in a certain rpm "row" only to find out that it created a bogus flow in a "column", up or down or both ways. Every engine is different and will respond differently. A differrent cam and exhaust combo will have different reversion effects.
I'll be finishing up a tune next week with a few low kPa humps. Luckily they're both down low so I should be able to tweak and test pretty quick right in the parking lot.
When i say i am getting changes and hits in the 80 to 100 kpa area i am saying i go out and do my AT runs and have hit thoes areas by the way i am riding during my AT.
at 1750 rpm in like 3rd gear i will roll on the throttle hard to WOT. i will run it up to 5000 rpm. When i look at my auto tune results the cells in the 100 kpa from 2000 rpm up to 5000 rpm have hits and my VE gets adjusted in thoes areas of my VE map. So for some to say you cant tune all the map unless you have wide band sensors is wrong.
Will you get a better tune with wide band sensors? I cant answer this. But i know for a fact that if i ride in the 80 kpa and at 4500 rpm, the basic will make VE changes.
If i check the log file after i do a run the A/F table in it shows that all cells have been changes to 14.6. I cant say if some maps wont let you change the entire map to 14.6 A/F, but mine does.
I hope i have explained so you understand what i am seeing and getting for results. So far i am 4 AT runs in and bike is running good no problems at all. i might try to play with the A/F mixture a bit. Then on to the timing.
So if you stop and think about it then, the PV will make corrections in the upper RPM and KPA range. if it is not accurate then why waste time doing it? Why not just get a bike dyno tuned and call it a day? So then am i to think that everyone on this forum that has hit cells in the upper ranges is running a risk? I would have to say then there is a flaw in the PV. And a major one then if it allows someone to do an AT and the changes could cause your bike to have a failure. If it is as you say and the numbers turn out to be bogus then dyno jet has alot of explaining to do to everyone that had VE changed in the upper ranges.
No where in any doccument that dyno jet has put out or fuelmoto has put out says do not accept any changes in any cell higher than 80KPA.
One thing I always wondered, but never asked anyone, is how even a pro-tuner gets around the bung placement. If the bike is tuned with a sniffer up in the head pipe, VE's set up, and then the bike is turned back over to the OEM 02's (in poor positions), it must make for some crazy AFV's. Properly set up VE's being sampled by poorly reading sensors? I guess this is where the GOOD tuners are well worth what they charge.
I usually use TTS, but the principles are still the same. One thing I will try is to grind the bungs down (I have a center that screws into the bung and a centered mill that goes into a portable drill. The mill center fits inside of the hole in the bung center.). Quite a few times, if I can get the O2 into the stream a little better, then it all works decently. If that is not possible, like the pictured D&D Boss pipe from 09... I will tune the low and high portions with WBos and v-tune the center.
Ummm... most bad sensor placements effect below like 2500 rpms. Above that, the pipe gets fairly full of gases. And... of course... I will sniff the 90kpa and up, anyways.
I use the dyno software to sniff the high MAP areas, by using Herko tuning blocks and riv nuts in the pipes. I hook the Dyno O2 sensor right to the pipes, and do a front and rear set of pulls to dial that in. NO copper tubes, etc.
That IS more work, and a LOT of guys will simply tune completely open loop. Which... works quite well. I, me, am a fan of closed loop fuel strategies, so I will take the extra time to use two different tuning processes to get it all dialed in.
You ARE 100% correct that 'sniffing' a pipe then trying to 'force' those settings with a poorly located set of sensors WILL make the AFVS go wild. AND... I have also found that simply sniffing, if the bungs ARE OK... still can make the AFVs go crazy. The only way to tune closed loop, IMHO, is to use the ECM to develop that portion of the tune. Other, better? tuners will disagree, but ????? There used to be a saying that to make a bike run good, one must make the ECM "Happy". I believe in that. Simply when you guys PV tune, or v-tune. or smart tune, or whatever... and you see your fuel tables set at, oh say... 14.4 AFR. That is what the ECM THINKS it is. It actually, for the most part, is NOT that exact AFR... but since the ECM THINKS it is, it works out very well. Now, If I tune to actual 14.4 AFR... the ECM will NOT recognize that as such.... and try to self correct with AFVs.
