Power Vision Information Thread
TedMan
Tried a data log run for the first time yesterday for 50 minutes. I finally was able to figure out how to compare the maps and the results have me confused.
The only changes are in the 750 and 3500 RPM cells from 27 to 70 KPa. The delta is -0.1 in all of these cells.
I thought the FM map was very good but shouldn't there be more changes to this map? Obviously I am a novice at this but would like to hear your thoughts.
Thanks
Thanks
In your previous post you said you did a log run, if this is true you should go into winpv and select "get log" select the log # you just ran and save it, next you need to open the tune you were running the log on and check the boxes for front and back VE's, afr, and front and rear spark advance. Go to file select "save selected values", this will save the selected values as a .pvv file. You can now go into log tuner and click to open the pvv file you you just saved, after you open the .pvv file log tuner will now let you open your log. Once you open your log select calc. tune and you should now be able to view ve deltas, spark knock, what cells you got hits in ect..
If you ran a AT run did you select "export changes" when you were done? I really can't think of anything else to check, the only other thing i could recomend is to try a couple more runs today and see if this was a fluke. If nothing works give FM a call tomorrom and I'm sure they can figure it out.
It sounds like you are trying to use onboard logging with the log tuner software.
Using the off-board method, _you_ need to setup a number of logging channels, create a modified map (retart timing, changing lamda or AFR, etc) flash the tuning load and then log.
Much easier to use the on-board AT function, where the PV will create and load the modified map for you, etc.
I did my first 2 via logtuner (factory cam and Andrews 26), then as a test re-did the A26 map via the on-board (as a test for the late beta releases) and came up with a map +/- 1% of the logtuner method. Currently dialing things in fore the new A48s using the onboard. Much simpler to use, I just pull the updated map into winpv every few revisions to compare.
Should say AT not active.
Hit "Enable AT" then select your base map.
Select "Basic"
PV will generate a modified tuning version of tune and flash to ECM.
WAIT until it tells you to turn the key off for 10 seconds (do not power off when it talks about ECU reset, too early).
After turning key back on, let PV boot and go back unter program, AT.
"Enable AT" will be greyed out.
Start bike, let it warm up....
Select "Datalog", it will go into the AT screen.
The "Log Start" button is for creating an extra log for review by log tuner, is not required.
The "Mode" button will cycle through various screens.
Once in datalog under AT it will be logging data and will auto-save every so often and whenever you come to a stop.
Ride for 15 - 30 minutes, get some good fill in the center.
Stop, exit datalog.
You will see min/max /avg change values, etc...
Kill the engine (run/stop switch), flip switch back on.
Hit export learned and save to open slot.
Hit "Disable AT". This will stop AT but leaves the tuning map loaded.
Hit "Enable AT", this time select the map you just exported...
Lather, rinse, repeat.
I start with at least 4 15 - 30 minute sessions just running around town easy to get solid fill for most of the regular riding range.
After that, I move to much longer and multi-session (you can put in AT mode, go riding a couple hourse, park for the night, ride a few hours the next day, etc. before exporting).
The point of the later long session is to try and get 50+ hits everywhere I can reasonably hit, so my last cycle tends to be riding a couple hours a day in varied conditions for multiple days.
You can always download the created maps and compare step by step in WinPV.
In general, you _should_ see minor changes in eny cell where there are enough hits. A good run on a well mapped bike would see semi-random shifting of many/most of the hit cells by < +/- 2%.
Check out <http://www.youtube.com/watch?v=l1fppB5rSYo> posted by DJ.
