Power Vision Information Thread
In Pro mode, you can tune fuel and spark simultaneously; however, Dynojet recommends to address fuel first, and then focus on spark. To do this, after you've completed tuning the fuel (via adjustments to your VE tables) and flashed the corrected tune file to your ECM, you can then start a new AutoTune session that's focused on spark corrections. In the settings area of AutoTune you can set Max VE Learn to 0 and Max Spark Learn to 10. This will disable AutoTune's ability to change fuel, but allow it to monitor, record, and eventually correct spark advance based on knock activity.
Dynojet recomends not using spark learn function in AT basic, but they say you can use it with wide band sensors. This has always had me puzzled because i assumed that with AT pro it would also retard the timing during an auto tune run. But i dont know. maybe it doesnt because the A/F ratio is set in the 13 range.
The way I do it is just do a data run when the urge hits me; or, I see/hear some knock, just hit the datalog button and try to replicate the knock. Then run everything through log tuner and see what changes, then save. I can dial in my spark knock corrections quickly this way.
Also curious as the the AFR tables some of you came up with and if you have multiple AFT tables you use
Looking at my Fuel Moto tune ver. the stock tune there were not a lot of changes to the AFR table or the timing tables
If your bike does not ping during the cooler riding season, but develops ping during the summer months, try pulling more at the relevant causal temps. Use the datalogs to find the temps and maps where the ping occurs and adjust accordingly.
The solution (based on input from FM) was to pull 3 degrees using Quicktune. Solved the problem for the rest of my trip. When I got home, I looked at the timing section of the tables using WinPV more closely, and found these heat related tables.
The ability to pull timing based on engine heat sounds like a great idea. But I'm not certain that the standard tables are doing enough. Before I start messing around with this, wondered if anyone else had explored and experimented.
Thanks for any input. The amount of info in this forum is awesome, and nearly overwhelming.
I just recieved a reasuring E-mail from Jamie at FM. It seems I just worry too much.
I have been looking over my logs and it seems most of my knocks while ATing were in the higher MAP/Kpa columns at lower RPM's, Trying to fill in all the cells in the upper right corner.Hell, I never ride like that, We all know the best way to gain 10 HP is to downshift. So I will try the quicktune approach to the vibration I feel but can't see in the logs. Then manually adjust the spark tables after settling on how much and where to reduce. Thanks for all your input.
Here's Jamies reply,
Hello, the AT and general logging are both reading back the same info off the data bus. If you have added timing and you are getting some spark knock you are going to need to go back the other way. You are not going to damage anything as long as you are not getting massive detonation and are forcibly running the motor under load, if the knock control is pulling timing within its limits that is going to be normal operation. On a well tuned bike is will be common to get some small knock events here and there, again as long as they are within what the system can control.
Thank you.........Jamie
Found this also, In the future when I add cams, PR's,etc..and possible dyno time I will beware of this,
• ECM was previously tuned with TTS Mastertune o When an ECM is flashed with TTS MasterTune, it puts a proprietary lock in the ECM. You or your tuner must have saved the original backup (.mte file), that flashed back in the ECM with the TTS’s MasterTune.
o The Power Vision, Screamn’ Eagle’s Super Tuner, or even the Digital Tech dealer tool CAN NOT enter flash (read or write the calibration) on that particular ECM. That being said a guy needs to be careful when using a TTS device, because if you’re out on the road and need service, or diagnostic work you’ll need a laptop with TTS Mastetune, the flash dongle, and the original .mte backup file.
o If you don’t have the .mte backup file and the dongle, or access to any TTS dongle, you’ll need to replace the ECM with a new one or send the existing ECM to TTS to be unlocked!
• Aftermarket or Harley-Davidson genuine accessory speedometer / tachometer clusters. o These devices can interrupt the communication, or cause intermittent communication on the data-bus to the ECM
o Removing the fuse to the cluster usually resolves the problem
