Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
The VE's in the VE tables shouldn't change. The changes will be profiled in the AFV table which unfortunately we can't see. Assuming he doesn't smooth the final cal he will be fine.
That's what I was trying to say. Maybe I should take a course on brevity
I have a couple of questions if someone doesn't mind answering.
Everytime I want to run Auto tune do I have to first load up the original map?
I ran Auto Tune yesterday and then flashed the tune to my bike. But If I want to run auto tune several more times, can I just leave my saved auto tune on the bike and just run auto tune again? Then flash?
I ask because I read somewhere that I should always load up the original map before running auto tune.
From: Western Illinois, land of bad roads, and corrupt politicians
I just want to be clear.
Load the last autotune that you exported. Repeat until you are satisfied with the result.
If you keep loading the original map, you won't see any benefit to running it over and over.
I just changed mufflers. Went out to run an auto tune. Will not hit any cells, just has message across screen WBF:L.
I have the auto tune with WB.
Any idea what has happened?
Dennis
Dennis
WBF:L indicates the wideband O2 sensor is low (< lambda 0.68). This is usually during warmup. Let the bike get to operating temp.
could stailjim or wurktruk or someone with a thorough understanding of CLI please take a moment to explain what that is and how to use it to monitor the conditions of our tunes.
i think i have an idea about its meaning and implications but i would love to see a good "how to" on this subject as i think it would help a lot of people here.
That is what I did I only smoothed the whole table 1 time and that was it. then I ran several more 4-5 AT runs and have not touched them since the last run. There are some peaks and valleys but not drastic at all. I probably even ran more AT runs then I needed to.
I would really like to understand making timing changes and how to know if what I am doing is working( seat of the pants)
Dammit...something else I didn't know I needed to know.
So, how do I smooth the VE tables? I have some very sharp peaks in mine.
