Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
If you look to the upper right of the AFR table you should see a little box followed by "Show air fuel ratio....." Just check this box to convert from lambda to stoich.
Got it, I had the box checked and was entering the values (13.9) in the Stoich format. I just see STOICH at the upper left on his map and mine says LAMBDA in the upper left. I just didn't want to mess anything up.
Am I the only person that is having bad luck with the Power Vision?
I have a completely stock 2012 Sporster 1200 Custom.
Every time I run a AT on the stock base map it gets worse, almost all the cells are heading in the lean direction by 5-10%.
These bikes are already very lean from the factory, this ain't good.
I've run Dynojets 'Improved Stock Tune' but it is a open loop Power Commander tune, Pig Fat Rich and a lot of stuff is turned off and not used due to the older technology. I really wanted to just improve my stock tune and keep the closed loop for all its advantages.
I guess I really need to just find a proven tune to load in and see how it runs.
I'm a little unsure of why you would buy a PV for an otherwise stock bike. What are your goals or plans that brought you to purchasing the PV in the first place? (Usually folks start with new pipes/slip-ons and an AC to allow the bike to breath better.)
Have you tried running the AT against DJs "improved stock tune"? Did you buy this from FuelMoto or another vendor?
I haven't noticed a lot of Sportster 1200 folks out here. Have you tried asking in "Sportster part of HDforums too?" ..just in case one of them has been there and solved your same problem.
Hopefully some folks will come along to give you some advice.
Hippie.... help me out here man.... the second table is supose to be a 14.2 A/F table correct? maybe my eyes are not working today but i see 14.6 in the cells?????
So the answer I get about that is that the 14.6 in this table is a "software switch" which then refers the software to the Closed Loop Bias setting and when that is 720 you are at the riches end of the settings. = approixmately 14.2AFR
I'm a pretty much a noob, with enough info to be dangerous, but this is the explanation I received from both DJ and FM. so YMMV
I'm trying to change my AFR table to the 13.9 table listed about and try it out for more power. When I open my current map it lists AFR in Lambda and the above table is AFR Stoich. I looked and don't have a Stoich table on my tree?
See I have an 07, non-Throttle by Wire, hence all my maps are based on Stoich, while the newer bikes are based on lambda.. same thing, just a different way of measuring it.
..and yes, I believe by checking the box you get to make the changes using Stoich AFR
I did not get the Power Vision from Fuel Moto, it was a gift, so no maps from them.
Dynojet only has 1 map for my bike, 'Stock Improved Tune' its an imported Power Commander tune that is open loop. A lot of stuff is turned off so this tune could work with the PV. DynoJet recommended that I really not use it and just AT my stock tune.
I was hoping to eliminate the surging, heat and lean factory settings by using the PV to tune them out but it appears to be heading in the wrong direction, leaner in a lot of areas.
So I'm stuck with only 2 Tunes, DJ and my stock one that I can AT and neither seems to be a good route to take.
My bike does not run 'bad' with either route I take, just expected more of an improvement. I was expecting to see VE's head toward the richer side by 5-10% and the temps go down some and eliminate surging at cruse.
I know how to use it properly. Been twisting wrenches for over 50 years and my career is in electronics 40+ years. No problem in understanding and using the unit at all.
Just really don't understand the results I'm getting.
Yeah, I understand better now. The surging is something for concern for sure.. and I'm not familiar with Sporties, but my guess is the EPA is forcing the breathing to be minimal and emissions to be minimal. I am guessing you have a Catalytic converter on that bike?
Sounds to me like you got all the same problems (or more with the surging) as the Twincam engines. Might be time to break out a few pesos and eliminate the cat, put on a decent air cleaner and some less restrictive mufflers. [I just went to the DJ sight and notice that all of the tunes they have for Sportsters, even with mods are all PC imports. There's an opportunity for some DynoTuner like FM I would think.]
I wonder if how Sportster owners are dealing with this? Or are they all just looking for loud pipes and hot womin'?
Keep us posted on what you find and any solutions.
