Power Vision Information Thread
Old Sep 8, 2013 | 04:55 PM
  #5341
oldhippie's Avatar
oldhippie
Originally Posted by jammerx
EITMS Temperatures on and off What have you set them at? Mins Max? I am looking to have it so EITMS is enabled and on pretty much when the bike is warmed up. Is there a down side? I don't see one.... It seems the 14's are like that. Let me know thanks.
I would think this would depend a lot on where you are and how much you need the protection. I mean if you're in Dallas, and riding to work in downtown in the summer time with a hopped up engine, then you prolly want a whole bunch of this and maybe be even more aggressive than stock.
On the other hand, if you are in New England, and it rarely get's above 90, and all you do is ride in the country and don't spend much time in traffic, have an oil cooler and don't run hot to begin with then do you really need it?
I think you're bike owners manual will tell you the conditions and temps the stock config uses, and the info in WinPV also tells you what stick settings are for both Mode 1 and Mode 2.
Old Sep 8, 2013 | 04:58 PM
  #5342
oldhippie's Avatar
oldhippie
Originally Posted by Crazylegs
I logged my Harley stage one factory tune and there were some knock events.
I see a small number of them too on every ride, but it's like less than 20 for either cylinder for 200+ mile rides. ...and it's nothing I feel or hear.
Old Sep 8, 2013 | 08:07 PM
  #5343
Rhombus's Avatar
Rhombus
Default Basic Tune - I've confused myself
Can't seem to find exactly this question. I've apparently managed to confuse my self with autotune basic. I'm performing these steps
1. Turn ignition to on, tuner boots up.
2. Select AT and 'enable AT' (it then asks me to select a map)
3. Select the map FM sent me for my bike
4. Tuner loads the map and then reboots ECM followed by turning ignition off for 10 seconds.
5. (wait ten sec.) Start bike, tuner boots.
6. Go to AT and select 'Data Log' The data log comes on. Sometime with a log, sometimes without
7. Ride bike.
8. At end of ride, exit datalog(exit the green screen back to where I can export)
9. Export learned.
10. Select slot to store new map, then exit.
11. Turn off bike, wait 15 seconds
12. Select custom tune, select the tune I want to load and then 'flash'
13. After flash system asks to turn ignition off and wait ten sec.
Here's where I'm confused, and perhaps my steps are wrong. I hook my PV up to my computer and run WinPV. I compare the new "I assumed tuned" map to the original map, and they are identical. I'm sure I'm missing something easy here and I feel like and absolute moron right now. But I've stared and stared at the manual and I'm just not seeing where I've messed this process up.
Someone give me a big DUH moment please. :-) Thanks.
Old Sep 8, 2013 | 08:19 PM
  #5344
fullautomike's Avatar
fullautomike
How many knock events are OK? Some say none, some say a few. I'm just about down to none, but I some times get a few. I took a 300 mile ride, and only one log (about a 20 minute log) had a few knock events. I thimk my current tune might be the one, so far no knock events, time will tell.
Old Sep 8, 2013 | 08:27 PM
  #5345
fullautomike
Rhombus, your new tune on your PV will be named something like, AutotuneResults001, right?
Old Sep 8, 2013 | 08:30 PM
  #5346
Rhombus's Avatar
Rhombus
Yes - Auto Tune 004.0 - which is the one I exported and then flashed. I'm probably have missed something mundane here.
Old Sep 8, 2013 | 09:20 PM
  #5347
oldhippie's Avatar
oldhippie
First thing you should do when AutoTuning is after you hit Datalog... you want to see the green screen, and then if it doesn't come up in "HITS" mode, cycle the Mode button on the green screen till you see "hits". Then you will be able to see the areas of the map you are covering as you do your autotuning while riding.
Now, when you are connected to the computer.. (first to a Client Update to make sure you have the latest firmware in your PV) then:
1. So you first do a "Get Tune" to pull the AT004 tune from the PV
2. Then you need to use the Load Compare button to get the previous tune from your Autotune database on the computer.
Not you can view each tune's VE screens by clicking the "Active" and "Compare" buttons and also look at the Delta. Look at the Delta as a percentage by going to the menu and clicking on the "Compare Menu" and then the pull down select "View as Percentage".
I hope this helps. If your not seeing the AT Datalog green screen, then you maybe haven't "Enabled Autotune" first, but it sounded like you had. But I don't like that you aren't seeing the green screen hits.
I hope this helps..somehow. Sounds like you are doing it all right.. but you should see yourself getting hits on the green screen.
Old Sep 8, 2013 | 09:23 PM
  #5348
Smokey Stover's Avatar
Smokey Stover
Did you hit YES when prompted to reset trims? If not do so.
Old Sep 8, 2013 | 09:27 PM
  #5349
Rhombus's Avatar
Rhombus
Thanks for the info. Went for another ride tonight and made certain I hit mode until I was in the "hits" screen. I see some red and some green after riding for a while I'm not seeing any deltas on WinPV, which is what has me totally confused.
I did also reset TRIM when exporting.
Old Sep 8, 2013 | 09:36 PM
  #5350
Smokey Stover
Thanks for the info. Went for another ride tonight and made certain I hit mode until I was in the "hits" screen. I'm not seeing any deltas, which is what has me totally confused.
When your flashing the new tune to the ECM hit "YES" or your just loading the previous values.
