Power Vision Information Thread
Old Jul 5, 2013 | 06:44 AM
  #4941
lhgdale's Avatar
lhgdale
Originally Posted by goats
did you adjust your spark in any way for this AFR set up ?
No, I have not adjusted spark. The tune started out as the FuelMoto tune for their 2-1 exhaust and woods tw-222 cams setup. I am learning one area of the PV at a time. First VE's, now AFR and next spark.
Old Jul 5, 2013 | 06:49 AM
  #4942
lhgdale's Avatar
lhgdale
Originally Posted by Crazylegs
So would you be running at 13.5 on the highway? What does PV show as your milage?
I am looking for better performance and cooling. I couldn't care less about a few MPG. I will look at the MPG next time I take the bike out (hopefully today). We have flash flood warnings here in AL.
Old Jul 5, 2013 | 08:06 AM
  #4943
fullautomike's Avatar
fullautomike
Maybe you should go to quick tune, spark and add 2* to the flat area and see what happens. That is temporary just so you know.
Ok I'll look into the quick tune. My question is do I add 2 to the number or take 2 away from the number to add 2* of timing?
Old Jul 5, 2013 | 08:56 AM
  #4944
Linville Lion's Avatar
Linville Lion
Add to the number...the higher the number, greater the advance.
Old Jul 5, 2013 | 09:55 AM
  #4945
fullautomike
Thank you, that's what I did, but I start to over think things and I start to wonder.
Old Jul 5, 2013 | 04:29 PM
  #4946
stailjim61's Avatar
stailjim61
Originally Posted by lhgdale
I checked my plugs today after 100 miles of running the 13.9 AFR.
The plug on the right is the rear cylinder and the left is the front cylinder. They look pretty good to me.
I decided to try the AFR at 13.8. I took the bike out for about 20 miles today and it seems to really like the AFR at 13.8. I'm gonna re check the plugs after a 100 miles or so just to make sure it's not to much fuel.
The plugs won't really give you much to go on. Back in the day a nice 100 mile jaunt down the freeway if the ends of your pipes and plugs were a nice brown color you were good to go. Nowadays with all the crap in the fuel color can be misleading. Can't really see in the pics but if they're just a tad off-white color you're probably pretty good.
Old Jul 5, 2013 | 04:37 PM
  #4947
stailjim61's Avatar
stailjim61
13.5 on the freeway would be a waste of gas. 14.2 is plenty for a steady cruise mode at freeway speeds.
Old Jul 5, 2013 | 04:54 PM
  #4948
NPW's Avatar
NPW
I was wondering if, (assuming VE's are <5%) running open loop all the time is in any way detrimental to a modern 103 motor. Nothing outrageous, just like 14.2 in the cruise. Would this screw me down the road with carbon build up?
Old Jul 5, 2013 | 05:05 PM
  #4949
stailjim61's Avatar
stailjim61
I think it's going to be a gas hog running that rich. I'm willing to bet you'll lose 5 MPG with those AFR's. If it's a barhopper and you dont care about mileage then it's fine. If your VE's are good to go you might want to make a leaner tune for the freeway. Store them both and reflash when needed. Or, if you find the rich tune you have to be sucking down the gas just go into the RPM and kPa areas that are your normal cruise areas and lean them out a bit.
One thing to remember is 13.8 may feel great on one bike and make another bike a little on the soft side. Richer isn't always better. Each bike, depending on the build, will have it's own happy spot. So, if someone says they run 13.8 and his bike runs great it doesn't mean every bike will run great at 13.8. I find 14.2 to be a pretty decent compromise for MPG and overall driveability. But, that might not be the "just right" AFR for another bike. Running 13.8, especially in the low load / low RPM / cruise areas, won't get you much. It won't hurt anything, but I don't think you'll gain anything either.
In the end all that matters is if you're happy with the way it performs. Try out different combinations and eventually you'll find the right one for your bike and riding style.
Old Jul 5, 2013 | 05:21 PM
  #4950
stailjim61's Avatar
stailjim61
What will screw you up is the breathers feeding the intake, but that's another story.
If your bike is non-cat 14.2 will be more than fine for a long long time.
If it's a cat bike your converter might not like you, or not last as long. They don't like being always rich or always lean, away from stoich. That's just one of the reasons the 02's switch between rich and lean constantly. If you go open loop 100% you'll be negating that part of the systems equation. I'm not sure if 14.2 would be enough to cause a converter to act up though, so that ones up to a cat-bike owner to research. Maybe someone with more knowledge of the tolerances of converters can chime in, for those with cats.
