Power Vision Information Thread
Old May 20, 2014 | 09:19 AM
  #5941
peg20's Avatar
peg20
The knock detection depends on the stock coil and wires. If you change them, it could stop the knock detection from working. If your ECM is generally detecting and dealing with knocks, then changing these components out could cause it to run more advanced than usual.
Old May 20, 2014 | 09:35 AM
  #5942
Smokey Stover's Avatar
Smokey Stover
Originally Posted by JeffJA
So, on my 09 sportster, its been running great with autotune runs, all of a sudden after i did a DK coil relocation with SE wires, it decel pops from 2400rpm to about 1400rpm, i doubt it has to do with the coil, did another AT run and it said something about being "maxed" or " capped" not sure what that stuff mean, i do have the quick tune decel fuel option up 15%
But its still popping, i have NO IDEA how to adjust anything from my PC at home, only with the PV on the bike, any ideas?....
Thanks
decel enleanment is opposite what would be logical, raising the value decreases fuel,lowering it adds fuel and cures most popping.So try putting the 15% back and lowering it another 15% and see how it goes,May need to go lower I.e.30 or 40%
Oh and plug wires can make a difference to the ion/knock sensors
Old May 20, 2014 | 09:44 AM
  #5943
nhrider1's Avatar
nhrider1
Originally Posted by jetfixer62
Ok, I still have a couple hundred pages to go to read this whole thread, but I wanted to jump ahead to ask a question. I understand the concept of tweaking the VE values during the tuning process to achieve the desired AFRs. (Or having AT do it) I want to look at desired AFRs vs actual AFRs. Am I understanding correctly that you have to look at the datalog file via PVtune to see the actual values? When I did my AT runs I hit 'start datalog', and I did generate pvv files that I imported into my laptop. I set up all the folders, and they are in there but have a lock symbol by them. When I try and open them using PVtune it shows the folder empty.
Did I need do something else to set up the datalog?
Do I need to do something to enable seeing the log files with PVtune?
I'm using AT basic, and I have an '11 limited.
Any help appreciated.
BTW, just read the TTS manual. There are some really helpful explanations in there. I am getting there!
You have to open the saved datalog file with excel to view it. WinPV can't view the files directly.
Old May 20, 2014 | 03:52 PM
  #5944
oldhippie's Avatar
oldhippie
Just looking for confirmation on the Spark Tables. If I identify knock event hits do I decrease the number hence retard (subtract) timing from that cell?
In other words, does increasing the number in the spark table advance timing and decreasing the number retards timing?
Old May 20, 2014 | 04:03 PM
  #5945
UltraNutZ's Avatar
UltraNutZ
correct. what i do is where I see knock, I retard that cell and the cells immediately surrounding it by 3* then see what if any difference it makes.
Old May 20, 2014 | 04:06 PM
  #5946
nhrider1's Avatar
nhrider1
Increasing the number advances timing. Decreasing the number retards timing (by decreasing the advance).
The number in the tables is the number of degrees of spark advance.
Old May 20, 2014 | 04:34 PM
  #5947
oldhippie's Avatar
oldhippie
Exactly what I am doing.
Thanks!
Old May 20, 2014 | 04:36 PM
  #5948
oldhippie's Avatar
oldhippie
Thank you. I thought that was the case, but couldn't quickly find that stated in the docs. althoug if I pour through them tonight I will prolly find it.
It would be nice if it said that just below the table in the comments section.
Old May 22, 2014 | 04:10 AM
  #5949
topfun's Avatar
topfun
Read the User Guide. Dynojet does not recommend using this feature in Autotune Basic. It is designed for use with Autotune Pro. Remember Autotune Basic retards timing 4 degrees.
When used with Autotune Pro it can only remove timing, based on knock sensing. It can not add timing. If no knocks are sensed, the timing will not be changed.
If you want to adjust timing in Autotune Basic, learn to use Log Tuner.
My understanding is we have to set the value circle in red below picture to 0 before starting with auto tune. So, after "auto tune" will we have to revert it to 1 again with the final map before sent it to PV... Is this correct ???
Old May 22, 2014 | 07:10 AM
  #5950
nhrider1's Avatar
nhrider1
Yout understanding is Incorrect.
Leave the switch values WinPV alone. They tell the ECM if the vehicle has Knock Control. Check the Knock Control box and set Knock Control to 1=On.
Autotune basic has Max Spark Learn set to 0 to disable this feature. When Max Spark Learn is set to a setting greater than zero the feature is enabled and limits Max Learn to the number entered.
Press Program Vehicle>Autotune>Settings (in the Power Vision Module) to edit autotune setting like Max Spark Learn.
Hope this helps.
