Power Vision Information Thread
Old Feb 16, 2015 | 12:04 AM
  #6811
Gommee's Avatar
Gommee
Devil's Advocate
Originally Posted by ke5rbd
The pro user is no longer available in the updated software. You can probably hook the PV to the computer and run the UPdate Client from the programs menu. You have to have Win/PV closed. After all the updates you can open Win/Pv with PV hooked up still and open the Tune in question and Select Power Vision from top menu then select Update Tune using PV. If that doesn't fix the missing data then FM is best bet. FM or Dyna Jet either can fix you up on the eliminators. Just turning off O2's in the Limits and Switches isn't going to stop the engine light.
Originally Posted by Smokey Stover
Normal is the only setting now They combined Basic and Pro into normal. As for seeing all the items in available in your tune tree, Load tune into WinPV, Click the Power Vision menu button, then UpdateTune using PV
Thank you!
I can now see all missing values in tune tree. Set closed loop to off.
Still get O2 engine code as stated above. Still think I have to call Fuel Moto to find out if I need the O2 eliminators or if the have a fix for the engine codes.
Old Feb 16, 2015 | 03:28 PM
  #6812
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by Gommee
Thank you!
On Dyna & Softail CANbus models there are a couple of things that need to be toggled to shut off closed loop completely, I received your email and will get everything turned off in the map and shoot it back out to you.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Feb 16, 2015 | 03:59 PM
  #6813
Gommee's Avatar
Gommee
Devil's Advocate
Thanks Jamie!
Always a pleasure to deal with you!
Old Feb 17, 2015 | 04:22 PM
  #6814
Gommee's Avatar
Gommee
Devil's Advocate
Received new tune from Jamie at FM. No need for O2 Eliminators, the updated tune took care of the O2 codes and engine light.
Old Feb 17, 2015 | 04:34 PM
  #6815
UltraNutZ's Avatar
UltraNutZ
my question is why would you want to tune a bike that's not run on the drag strip completely in open loop?
Old Feb 18, 2015 | 09:35 AM
  #6816
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
You have a lot of flexibility on how you choose develop and maintain your tune, closed loop is not always the end all solution. He has the option to use either the factory or wideband sensors. He can use the widebands to develop & monitor his tune, and if he chooses to run closed loop he can do so with the stock sensors.
Old Feb 18, 2015 | 09:37 AM
  #6817
UltraNutZ's Avatar
UltraNutZ
ah.. I misunderstood then.. so he's tuning open then turning NB sensors back on..
Old Feb 18, 2015 | 09:46 AM
  #6818
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
I am not sure, however the options are open. No problems running a properly tuned bike in open loop and it opens up your options for commanded AF mixture, with his setup he also has the ability to monitor AF in real time and populate tune correction very easily
Old Feb 18, 2015 | 11:02 AM
  #6819
UltraNutZ's Avatar
UltraNutZ
I know there are a lot of pure open loop fans out there but I'm not one of them. I don't feel there are enough compensating factors/range within the stock ECM to deal with a fully open loop tuned bike.
Old Feb 18, 2015 | 03:04 PM
  #6820
Red Dragons's Avatar
Red Dragons
What ever did people do before O2 sensors.
