Power Vision Information Thread
Old May 9, 2015 | 06:10 PM
  #7131
Andrea Capello's Avatar
Andrea Capello
I wish to autotune 0 TPS column as I believe is the first step to fix decel pops.
Otherwise we'll keep adding fuel but if we do not know the actual VE we'll NEVER know exactly what would be the AFR in that area.
I am not a guru tuner and I try to learn.
Some need to ride more, tune less!
I cannot find the added value of this.
Is it really the same, old sentence that old people always tell younger guys? C'mon...
Old May 9, 2015 | 06:18 PM
  #7132
airfuel's Avatar
airfuel
You are chasing your tail. It doesn't matter what the ratio at zero column is.
As per dynojet. To try to remedy decel pops, add 5% fuel and 5degrees timing in quick tune at the decel settings. Trial and error with this procedure will most likely eliminate/decrease decel popping. It has worked for many and varies from bike to bike according to modifications.
Old May 9, 2015 | 06:34 PM
  #7133
Andrea Capello
Thanks airfuel, I had already did that and got rid of decel pops that way.
Just figuring out if there was another way to reach the same point...
Old May 10, 2015 | 07:04 AM
  #7134
Sam2010's Avatar
Sam2010
Under tune items open fuel then to MPG Adjustment.
Does this number affect "R" Remaining miles that the bike displays in the odometer?
Old May 10, 2015 | 07:18 AM
  #7135
Andrea Capello
It should!
Why asking this?
Old May 10, 2015 | 08:43 AM
  #7136
Sam2010's Avatar
Sam2010
It should is not a very strong answer. It does or it does not.
You know saying if I have to explain why.
Old May 10, 2015 | 08:48 AM
  #7137
trintcole's Avatar
trintcole
4th Gear
Bike is a 2002 softail.
I'm running the autotune wideband pro kit. I've done several autotune sessions, and I've got all of my changes down to less than 1%. im confident I've gotten my fuel tables dialed.
When riding and watching the gauges while logging I've noticed a few things.
When commanding 14.5 ratio, my afr never goes below 15.
I set the fuel table to 13 across the board, which I think is where autotune pro sets them at. I ran about a 20 minute log. City driving and I got on the interstate. I opened log file with excel, sorted by rpm, split groups in 1000 rpm increments, and averaged what the actual afr was for each cylinder.
In all rpm groupings for both cylinders I was averaging about 12.85 when commanding 13. Pretty good in my opinion. I'd rather be on the rich side.
I did the same thing with the normal fuel table which is set to 14.5 and my averages for all rpm ranges was over 15.25. Some ranges up to 15.8 on varying cyclinders. The rear was consistently the leaner of the two.
Any ideas on this? Could this be O2 sensor error? How can I get this right?
Old May 10, 2015 | 02:18 PM
  #7138
bullast's Avatar
bullast
Alright...
Maybe a stupid question but...
Is the "Data Link Connector" what my PV plugs into on my '14 FXDB?
Its in my electrical caddy with my fuses and such.
I ask cause in the FM vids they say other ports look exactly the same.
Thanks y'all.
Old May 10, 2015 | 03:10 PM
  #7139
tstroud's Avatar
tstroud
Originally Posted by trintcole
Bike is a 2002 softail. I'm running the autotune wideband pro kit. I've done several autotune sessions, and I've got all of my changes down to less than 1%. im confident I've gotten my fuel tables dialed. When riding and watching the gauges while logging I've noticed a few things. When commanding 14.5 ratio, my afr never goes below 15. I set the fuel table to 13 across the board, which I think is where autotune pro sets them at. I ran about a 20 minute log. City driving and I got on the interstate. I opened log file with excel, sorted by rpm, split groups in 1000 rpm increments, and averaged what the actual afr was for each cylinder. In all rpm groupings for both cylinders I was averaging about 12.85 when commanding 13. Pretty good in my opinion. I'd rather be on the rich side. I did the same thing with the normal fuel table which is set to 14.5 and my averages for all rpm ranges was over 15.25. Some ranges up to 15.8 on varying cyclinders. The rear was consistently the leaner of the two. Any ideas on this? Could this be O2 sensor error? How can I get this right?
Probably just an error in how the Powervision calculates VE's. Try adding 5 to all the VE's and see how it does then. Maybe you will need more or less than 5.
Old May 10, 2015 | 03:12 PM
  #7140
tstroud's Avatar
tstroud
Originally Posted by bullast
Alright... Maybe a stupid question but... Is the "Data Link Connector" what my PV plugs into on my '14 FXDB? Its in my electrical caddy with my fuses and such. I ask cause in the FM vids they say other ports look exactly the same. Thanks y'all.
The other port that looks the same is under your seat and it is accessory power. The one in the electrical caddy is the correct one.
