Power Vision Information Thread
NOTE: This will wipe out any maps and logs on the device so use your noggin and back up your stuff to your computer BEFORE you do this.
Right click the link below to download a recovery file and save it to a local drive on your computer:
http://dynojetpowervision.com/Downlo...B-0.0.9.11.pvr
Install the above recovery file to your Power Vision by following these steps:
1. While holding the “power button” down on the face of your Power Vision plug in the Power Vision via USB to your computer
2. You should notice that the screen of the Power Vision has many colored bars and says, “Recovery Mode”
3. Launch the Power Vision Update Client
4. Highlight “PV Firmware”
5. Select “Update from Local File”
6. Select “PV Recovery”
7. Point to the file you downloaded from above
8. Finish the installation of the recovery and then proceed to update the firmware and tune database
*Updated link 2/4/2015 - UN*
Well, where were you a couple weeks ago, when I really need this info!! ?
just kidding-
I printed it out and filed it away for futue reference. good to know
thanks
FB
balloon.... condom...... bread wrapper?
Balloon does work good I'm serious.....
But another thing I do is un plug the power vision cable from bike if I think there is a chance of anything happening "on the other end of the cable" I don't want to chance shorting it out or scrambling the bikes brains so to say.
