Power Vision Information Thread
I just don't want to cause any issues.
Ive got the auto tune pro, as well.
I havent delved into the VE or AFR parameters yet.
Almost blinding... a bit intimidating.
I just gotta dive in.
I can read this whole thread until I'm blue in the face but won't really understand until I actually do it.
Again, just don't want to do any harm to anything.
Read this particularly section 2.6 on the page: http://diag4bike.eu/help/hd/hd-tunin...l-maps-summary
This is short and good as well, scroll down to section 3.5: http://diag4bike.eu/help/hd/hd-tunin...e/default.html
Some good clear examples and explanations on how VE, AFR relate to tuning HD Delphi.
I'm struggling to remove the decel popping which happens between 1st and second.
I have a fuel moto map. FM (Jamie) who has been great with help on maps but still have no luck removing the popping. I have checked all the gaskets and have no leaks which I can tell. So I took the last map which FM created and have run 6 auto tunes on it with a little better results. So can anyone take a look at the base map and the last auto tune to see what is changed maybe recommend some changes to help with this problem?
https://www.hdforums.com/forum/attac...1&d=1431478185
Thanks guys.
John
Sorry for jumping on this thread, I installed the new map from Fuel moto(jamie) and all is fixed on my end. Hats off to FM.
John
After that, with a stock Stage 1 bike, (no cams or other engine mods) you are pretty much done, other than working on getting any decel popping or other issues like that resolved.
Other things to learn to do is use the PV as a set of engine guages to look at engine temp, knock events and other parameters. These last couple of things are down the road for you. Don't get overwhelmed.. learn how to do and flash and Autotune run.
Last edited by oldhippie; May 15, 2015 at 08:30 AM. Reason: eliminate mention of Logtuner for PV2 bikes
Im sure there was a couple "holy sh*t" moments with a "just go do it dude."
Well, I did.
I shot him a PM yesterday with yet ANOTHER ridic question.
Right after sending that, I loaded Jamies map and rode.... and rode...
Bike ran GREAT!
The decel pop I was having with the tune that HD put on with the SERT is now a decel GROWL.
I love it.
Gotta get the Auto Tune hooked up still. Bit more involved than I expected but not intimidating like the tech stuff.
Thanks all!
There are other things you can do from there, like work on solving any pinging or engine knock you might have, but you may not have any. If you do, you can learn to run Logtuner (a separate Powervision program) and do some datting logging, while riding and then see if you need might need to adjust Spark timing tables.
That is unfortunate as I think LogTuner would still be a valuable tuning tool- But DJ does not really seem to offer much help or care at all with anything PV2-related. Seems like their sole any only focus now is on the Dynojet equipment stuff. Maybe FM will do something to get it to actually work again. Would require some simple code changes to the application that's about it.
Well, I did.
Bike ran GREAT!
I love it.
Thanks all!
What you could do is run autotune pro on the FM tune to get VE's 100% dialed in to your motor, then save it to a second slot in the PV2 as a new tune. you can load that new tune and ride it for comparison, and run another auto-tune session on it if needed. You may need 2-5 autotune sessions before it is within 3% or less of changes. once you are done with that you'll have reasonably accurate VE's combined with the other FM tune settings. once you do this a couple of times it's pretty easy- the only hard part is the first time and getting familiar with the PV2 and process.
http://www.powercommander.com/downlo...5449.19123.exe
Roger Roger
