Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Could you clarify " sometime has popping when get fast" so forum members can address your issue? Do you mean you get popping at higher RPM? Is this during acceleration or deceleration? Is this during autotune? What kind of mods do your have? Have you flashed your custom map based on your mods?
It would just help understand the issues you are having with your bike.
It happen durring pull clutch and acceleration at higher RPM. Already finishes autotune with more than 10 times and of course I have flashed with the final map and turn off autotune.
If your holding the throttle open while pulling in the clutch to upshift the popping you are getting may be from hitting the REV limiter.
The popping happened when RPM around 2000-2500. So I don't think it hitting the REV limiter. Any idea how to check it ?
2000-2500 popping isn't going to be the REV limiter. You could try lowering the values in the deceleration enleanment table 15-20% or if the popping is longer more drawn out, several pops, lower the AFR values in the 20 Kpa columb in the AFR table. Safe the before map, so if the popping doesn't improve you can undo the adjustments. Loose headpipe or muffler clamps could also contribute to your popping.
I bought a new cable and license from Fuel Moto to be able use my PV I had on my 2013 CVO RK on the 2015 RGS I just got. Updated the license put the tun they sent on to the PV and installed the tune ( stock RGS with Harley Davidson Night Sticks on it)
I went for a short ride and the instant MPG was way high and it seemed to get very hot very fast. Bike seemed to run OK
Fuel Moto is closed and I did get a hold of Dynojet and sent them files, was just wondering if anyone else had this issue and what they did to fix it.
