Power Vision Information Thread
You did not list your specific mods however if you are running one of our calibrations and have not yet done so I would recommend running three, 20 minute Auto Tune sessions. Between each session Export Learned and re-enable this map for your next Auto Tune run. If you continue to have any kind of running issue you are welcome to send us your Auto Tuned map for review and we can assist no problem, and if you need any help along the way just give us a call or email.
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
On the other hand, I haven't used my PV for anything but the guage function all season since I did the upgrade, so all sorts of new firmware and such has been put into some of the recent loads.
From our website:
Dynojet Target Tune is an optional accessory for Power Vision that adds a new dimension to Harley tuning. Target Tune incorporates closed loop fuel control utilizing Bosch wideband O2 sensors into the HD-Delphi ECM. Dynojet has evolved the OEM closed loop parameters and adaptive fuel control within the ECM to meet the needs of performance & tuning enthusiasts alike.
Allows the factory ECM to interpret and use wideband O2 sensor signals*
User defined AFR/Lambda targets over a broad range
Target fuel table from PV calibration is achieved in real time
Retains OEM closed loop, adaptive fuel control strategy
Learns and uses VE table corrections as you ride
Target Tune enhanced Auto Tune app on PV device
Does NOT interfere with dealer diagnostic / service tools
Direct plug in OEM style connectors connect to factory O2 harness
Model specific applications for Harley Davidson closed loop models
Available as upgrade kit without O2 sensors for owners of Auto Tune Pro
Fits 2006 and newer Harley Davidson motorcycles**
* Requires Power Vision Target Tune specific calibration
** ECM must be "closed loop capable" and have OEM wiring for O2 sensor circuitry
For more Target Tune info & pricing you can visit our website http://www.fuelmotousa.com/series-199126
From our website:
Jack
