Power Vision Information Thread
Old Jul 26, 2015 | 10:59 PM
  #7451
IKnowNot's Avatar
IKnowNot
IT IS CONFIRMED!!! it was all an ID10T error on my part :-)
Glad you found the problem, and everyone has a brain fart once in a while.
But if I were you I would take care of those exhaust leaks before I relied on any auto tune. After all, all the auto tune does is set the VE tables ...
Old Jul 27, 2015 | 04:51 AM
  #7452
goats's Avatar
goats
very true.
I never intended to actually use the new tune, just wanted to check out some things using the mode button that i am not very familiar with.
Old Jul 27, 2015 | 04:33 PM
  #7453
oldhippie's Avatar
oldhippie
Originally Posted by goats
hey old hippie, no issues per say, just wanted to reacquaint myself so i can help locals and also cause i was curios about something.
Good to see you back out here. We could use your help.
PS ...note the little upgrade I did to my ride. Yahoo (I can see one of those in your future. )
Old Jul 27, 2015 | 07:20 PM
  #7454
jrat69's Avatar
jrat69
I took my bike to have it DYNO Tuned today, the first thing I was ask was what year, it's a 2012. He then said Power Vison can not tune 2009 to 2013 touring models. They use map based VE's which can not be tuned. He did a trial run just to see where I was at, and said I was extremely lean on front cylinder under 3500 rpm, and said the only real way to correctly tune it was to buy a PC 5, and eliminate the Power Vision. I did switch back to the map Fuel Moto had sent me, the bike is still lean, but no longer critical, runs like crap. Anyone know anyplace in south central Indiana that can tune a Power Vision?
Old Jul 27, 2015 | 08:11 PM
  #7455
goats's Avatar
goats
i noticed that!! i bet thats fun as hell to ride now :-)
what is your mileage like now compared to before?
Old Jul 27, 2015 | 10:46 PM
  #7456
jammerx's Avatar
jammerx
Originally Posted by CVORoadKing2013
For me it is PV related. Again removing the PV the issue never happens
I have provided several files and information to FM and they are going to contact DynoJet.
I went as far has routing the cable from under the seat along my leg up to the handle bars and it still happens.
I just installed my PV today, rode it about 50 miles, stopped for gas, got the "NO FOB" (bike would not start either) cycled power, it started rode home, messed with it, can't recreate it, "googled" it via HDF and landed here. Its the PV/tune not doubt. I received my tune from Fuel Moto today. (its stock improved) I will keep it, but if I get a no start condition again, its done.
Old Jul 28, 2015 | 07:02 AM
  #7457
goats's Avatar
goats
Default locked tune?
i made some quick tune changes, made copy of current, opened in winpv, did what i wanted to do and saved/renamed.... now it is locked?
why and how can i change that?
Old Jul 28, 2015 | 07:04 AM
  #7458
goats's Avatar
goats
next time that happens try wiggling your keys.
the battery in the key fob MAY be getting a little weak.
shouldnt have anything to do with a tune.
Old Jul 28, 2015 | 09:39 AM
  #7459
airfuel's Avatar
airfuel
Nonsense!
Go to the Power Vision site or call Dynojet and find a tuner that has been through the DJ course to become a Power Vision tuning Center.
Old Jul 28, 2015 | 10:50 AM
  #7460
jrat69's Avatar
jrat69
The Dyno guy did suggest I set my AFR to 14, and set all the VE tables to 100, and then try a auto tune and see what happens. Any thoughts on this?
