Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Jack, my 07 EGC would show high numbers on the high end of the RPM range and WOT. The AT would work fine down lower, but always want to scale up, or cap when I got up high. I never got to the bottom of this until I took my bike out to FuelMoto for some engne upgrades.
LA Dog, this is something I never thought of but it makes perfect sense. Will try a few more auto tunes, and pull the tank and fuel pump. May just be a clogged filter, only way to tell is to pull it. Stock engectors should be fine for the amount of work I have done to the motor. And will not spend the cash for a dyno till I have completed the mods I want to do. Right now running in open loop only, well get the VE's closer before throwing more money at it.
Thanks,
Jack
Thanks,
Jack
Your data logging from normal / spirited riding would tell you if fuel delivery is ok at heavy throttle (high MAP) and higher RPM. Be sure to log for IDC-F and IDC-R (injector duty cycle) as well as INJ-PWR F and R (injector power as measured in milliseconds).
Open csv log file in excel
Sort "Z-A" for MAP and expand sort to cover all columns.
Look across the rows for your highest MAP at highest RPM's - What does the largest percentage show for IDC and what does the largest millisecond reading show for INJ-PWR? For example, on my Breakout I can hit 5000 rpm at 100 map and my injector duty cycle F/R is over 93%!
This data will help tell you if your fuel delivery system is adequate for the motor under all conditions, or if it needs to be upgraded.
Hey good to know! now if we could just have it download the trim values we could see what it actually does, from what I understand the TT does not change the tune so there is still no way to compare.
When the ECM is building adaptive corrections it is not making corrections to the actual calibriation side of things, it is storing the learned values as block learn in non-volatile memory. And while its not on the table at the moment, at some point we may be able to develop an application such as a screen on the PV where we could read back the corrections and overlay them with the PV calibration
Thanks for the added info and partial answer- I am hoping Jamie can give some added specifics. Yes the 18mm bungs would go into the same location as the present NB bungs. I would not use bung adapters but rather, cut and re-weld the proper bung on the pipe, or get pipes that come with WB O2 bungs. I'm curious about wiring because IIRC the HD ECM uses NB O2 wiring- so I'm assuming the WB O2 sensor wiring goes directly to the TT module?
The Target Tune module plugs directly into the standard O2 connectors on the factory harness, we then connect to the Wideband O2's. We generally recommend running these 18mm sensors within about 10" from the exhaust port, you cannot use an adapter so it requires using a pipe with 18mm bungs or welding them in place. Sensor placement and overall exhaust design are extremely important in this application. Open drag pipes, mufflers without baffles, and other exhaust variables that influence reversion can/will affect tunability.
See this is what I'm curious about is the auto tune with target tune. Does it work in the same mannor as AT pro as far as how it sets up the tune and logs and make corrections. I guess I can just wait shipping says my TT will be here first thing in the morning!!!
The TT-Auto Tune application on the PV is similar to AT-Pro, however the most significant difference is that TT-AT uses the actual AF/Lambda targets that are in the calibration rather than setting the entire Fuel table to 13.0 AFR like AT-Pro.
So those if us unlucky enough to not have closed loop, but lucky enough to have upgradable ECMs, can we still play with target tune (with my 04, upgrade to an 05 ECM)? And if so will I have to install narrow band as well or can I use only the air tune pro widebands I already have?
Target Tune is currently only supported on factory O2 sensor equipped models.
**Power Vision Information Thread**Sticky Approved by Admin
Jamie
I would really like to see the ability to apply the learned values back to the map to update it. Seems like the next logical step and would add huge value to Target Tune.
Jamie
If you are in TT-AT mode you have the ability to view the recommended +/- fuel corrections and apply them to the base map. If you want to view live corrections outside of AT mode you can view CLI and AFF for direct representation of the corrections being made in real time. There is also some really cool stuff you can do in Megalogviewer HD that I will put together and explain at a later time.
Just realized what you are saying. there is now a 3rd mode of the Autotune routine available that's designed to be used with Target Tune. Its in the public firmware. Will test that out. Will be looking forward to your megaloviewer info.
