Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
So I haven't connected my PV2 to my PC in a while, I decided to check if there is any SW update. Turns out when I plug in the unit via USB, it powers up and shows PC Link Mode Active, but the Powervision client and the Powervision Update client both won't recognize that the PV2 is connected. Thought it might be a driver issue, but I can't find any drivers in the DynoJet SW download section.
Thoughts? Also, I tried to push the power button on the unit to see if that would do anything, but it won't depress. Maybe it is stuck? For reference, the unit works perfectly on the bike. Thanks in advance for any suggestions.
Edit, now WINPV is recognizing the PV2 and I was even able to import my tune.
PV Update Client is still not recognizing the PV2.
Sounds like you have the WinPV software and the PV Update Client open at the same time. Close out of both programs and open up the Update Client and you should be good to go.
Hope the issue is that simple to solve, Jaime.
I might have had the WinPV open at first. Now it is closed and the Update Client is still not recognizing the PV2. I have a pop-up that states:
"Please connect your Power Vision to your PC with the provided USB cable to check for necessary firmware updates."
I click OK and another pop-up says:
"No Power Vision connected. Please check any PV's with a batch number below 110201 for a CRITICAL SYSTEM UPGRADE."
Is it possible that WinPV is still running in the background?
PV2 log data not correct? I was datalogging and looking at my csv in excel- I have my idle timing set to 16 F/R in the 750-1000 rpm lines up to 40kpa (idle MAP is typically 32-37). idle is set to 950rpm. CTS is disabled.
In my CSV log file, the logged data during idle events, 0 TP (e.g. sitting at a long light) shows 23-24 degrees advance for the 950 idle - both F and R. But, if I plug in the PV2 and view it real-time, the adv F/R shows correct for 950 idle, 0 TP at 16 degrees with slight variance to 16.5.
What's up with the captured log data - possible bug?
It depends on the specific calibration you are using however there are several other tables tied to idle spark. What you are seeing is likely Idle Spark gain which the ECM uses to maintain idle control. I would really need to see the PV monitor, logs, calibration, and have the bike in front of me so I could validate everything.
Here is my afr map. And Acceleration enrichment
seems to run fairly we'll now. Just wonderin if she is getting to much fuel untill I can get her on a dyno.
Reason: To add a picture
