Power Vision Information Thread
Old Sep 1, 2014 | 02:53 PM
  #6431
Hausguy's Avatar
Hausguy
Originally Posted by nhrider1
Look at your log files in Excel and see where the pinging is occurring. Subtract 2 degrees from the area where the pinging occurs and possibly adjacent cells.
Run another log and repeat until you get rid of the pinging.
I hear you but my question is: can a tune change over one tank of crappy (or low octane) fuel? It was NOT pinging before this event.
Old Sep 1, 2014 | 02:54 PM
  #6432
ghoticov's Avatar
ghoticov
I have another question.... why would the map that Dynojet have 0's in the 1700 and 2300 rpm range in the Active Exhaust Duty Cycle Table (for 1 - 4 gear). Shouldn't they all be 89.8 or does it matter?
Old Sep 1, 2014 | 05:19 PM
  #6433
WolfAngel's Avatar
WolfAngel
Default Re: PV1 issues.
Originally Posted by UltraNutZ
you don't have a PCV on the bike by chance do you?
I know what that is for car but did not know the bike has one too.
From the looks of some of the posts it just may be the firmware update that did it. I will check that out and see if that is the problem.
Old Sep 1, 2014 | 05:23 PM
  #6434
UltraNutZ's Avatar
UltraNutZ
yep.. I started seeing the issues after I posted this to you. Revert back to the older firmware and databases and you should be fine.
Old Sep 1, 2014 | 05:29 PM
  #6435
WolfAngel's Avatar
WolfAngel
Default Firmware version
Originally Posted by CVORoadKing2013
go back to the previous FW. You can download the FW from the Power Vison site
http://www.dynojet.com/powervision/p...Power%20Vision
The database I got from another member and he showed me were it is downloaded to on the PC but if you just got yours you probably have only done this update.
I just went to the site and they only have one firmware version up. Any idea where to get an earlier version?
Old Sep 1, 2014 | 05:30 PM
  #6436
UltraNutZ's Avatar
UltraNutZ
https://www.hdforums.com/forum/ignit...l#post13166006
Old Sep 2, 2014 | 03:17 AM
  #6437
WolfAngel's Avatar
WolfAngel
Default Got it thanks!
Ok went to the fuel moto site and d/l'ed that firmware update. will try it tomorrow and see what happens.
Old Sep 2, 2014 | 08:00 AM
  #6438
nhrider1's Avatar
nhrider1
AFV trim may have been adjusted by the tank of bad fuel. Run an autotune and select reset learned fuel trim values before flashing to clear AFV and restart the learning process.
Old Sep 2, 2014 | 12:01 PM
  #6439
Terryjft's Avatar
Terryjft
Default Trip Center - Distance
I would like to utilize Trip Center to monitor things. I realize one can (needs to) calibrate the fuel used. However, I am more concerned about the distance displayed. I found that the distance was often in conflict with my dash odometer. It would be missing mileage.
What I discovered is this:
*If I leave Trip Center on the display, the distance matches the odometer.
*If I go to other gauge screens to view other items (knock count, MAP, temp, etc.) and come back to Trip Center, this is when the PV "loses" miles.
This is far from desirable operation of the function. Does this occur for anyone else?
Old Sep 2, 2014 | 12:39 PM
  #6440
nhrider1's Avatar
nhrider1
Doesn't happen on mine. I have calibrated the trip distance to match the odometer. No problems and i don't bother to display distance.
