Power Vision Information Thread
Old Jun 18, 2011 | 02:09 AM
  #741
aclundwall's Avatar
aclundwall
Can someone explain what the fuel and idle trims are, and when they need to be reset (and when they don't)? I thought I understood this, now I'm not sure!
One post, way back, suggested they needed to be reset before logging. I mentioned it in a later post, and a subsequent reply said that wasn't necessary! Now, with the latest firmware, every time we flash a tune, the PV asks if we want to reset the fuel trim. But then it says its only necessary if we change anything to do with the air/fuel mixture (or maybe it says VE tables...I can't remember exactly).... Well, isn't that almost every time we flash a tune? What is actually happening when we reset these trims?
Old Jun 18, 2011 | 05:41 AM
  #742
Pass's Avatar
Pass
The trims are the new learned values... the desired values so to speak. Not every time you flash are you changing the VE tables (it seems like that now since that is what you are tuning). Later on, you may change just your spark, or a temp setting, or enabling something or disabling something. It would not be necessary to reset your trims.
You do not have to reset your trims pre-logging run. It just forces the ECM to relearn new values.
Old Jun 18, 2011 | 06:51 AM
  #743
TedMan's Avatar
TedMan
Originally Posted by harleycat225
Mine did the same thing. I figured out it was the cable. I ty-rapped it to the spark plug wire to keep it out of the way and it was picking up interference from that. Ran the cord under the tank wire console and al is now good.............
Thanks. That is probably the problem. Should I remove the whole tank, or just the console? Thanks again.
TedMan
Old Jun 18, 2011 | 07:27 AM
  #744
CrusingHarley's Avatar
CrusingHarley
TedMan
It is easier to remove the whole tank.
Old Jun 18, 2011 | 07:58 AM
  #745
TedMan's Avatar
TedMan
Got it. Thanks all for feedback. My base FM map is pretty close, just want to dial it in and the viewing gauge function is pretty cool.
TedMan
Old Jun 18, 2011 | 08:01 AM
  #746
Pass's Avatar
Pass
Really? I just ran the cable through the console and zip tied it to the cabling on the neck then up through the plastic gauge housing onto my handlebars. I will probably run it under the tank when I pull the tank to do my handlebars later.
Old Jun 18, 2011 | 09:19 AM
  #747
CrusingHarley
Remove 5 bolts ( 1 for the seat), disconnect the fuel line which is a quick disconnect and that whole area is opened up for an easy and neat installation.
Old Jun 18, 2011 | 10:46 AM
  #748
FX4's Avatar
FX4
Pass, on your bike, removing the fuel tank is a breeze. A bit more of a headache on an 07 but still not difficult.
Old Jun 18, 2011 | 02:03 PM
  #749
aclundwall's Avatar
aclundwall
Hey, thanks for the reply. Sorry to be so thick on this....but I still have a couple questions...
OK...by learned values, you mean the values stored in the adaptive table, that are applied during startup, right? If so, why wouldn't you want to reset these prior to logging? It seems to me that if the ECM applies 'adjustments' to the tune, it's going to change what is measured by the O2 sensors, and so adjustments calculated by logtuner are going to be off as a result. Sure, they'd be right for the tune plus the learned adjustments together, but they would be off if the trims were reset later....
Second question...the guide for the log tuner suggests turning off the adaptive control... Again, assuming that the adaptive control is the where the data in the trims comes from, I guess that means that while my tune has this parameter turned off, this is all a moot point, right?
Finally, when it comes time to reset these trims, when do you do it? If they are applied at startup, then I assume it's a waste of time to do this unless the engine is off, right?
Thanks,
Art
Old Jun 18, 2011 | 05:01 PM
  #750
kurtos's Avatar
kurtos
The instructins says that I need to have the stock ECM settings flashed onto the bike prior to using the Power Vision...but I dont have this map since I have been using a Screamin Eagle Pro tuner from the dealer.
How do I get the stock ECM-flash?
Regards,
Kurt
