Power Vision Information Thread
Old Jun 19, 2011 | 11:58 AM
  #751
captdave221's Avatar
captdave221
Default Stock Map
Take your bike to a Harley dealer and ask them to hook it up to Digital Tech and reflash the stock map. The map is a no-charge from HD so you should be only charged for the time involved.
Old Jun 19, 2011 | 12:00 PM
  #752
kurtos's Avatar
kurtos
Unfortunately my "closest" dealer is 250 miles away...:-(
Regards,
Kurt
Old Jun 20, 2011 | 03:24 PM
  #753
iclick's Avatar
iclick
Is anyone currently doing datalogs with the AT-100 Pro using the old dual-module unit? If so, could you report back any problems? Please provide the year-model of the bike and a description. Thanks.
Old Jun 20, 2011 | 06:25 PM
  #754
FX4's Avatar
FX4
With Jamie's help I have VE moving again but I am very well dialed in. It's less than 1% in most cells. So that isn't my lazy throttle issue between 2500 and 3000RPM.
Old Jun 20, 2011 | 07:23 PM
  #755
hornhonker's Avatar
hornhonker
Mine are working. Getting resuts after upgrade to logtuner 1.06
Old Jun 20, 2011 | 08:08 PM
  #756
Linville Lion's Avatar
Linville Lion
Does anyone know what improvements were made to 1.06?
Old Jun 20, 2011 | 08:59 PM
  #757
captdave221
Yep I am. I have the old dual AT modules and I am getting lockups, blank screens, very slow response on the gauges. It acts like an old 286 computer trying to run windows 7 on it. LOL. I have unplugged the O2 sensor wire and the gauge screens still seems slower than before. I just keep plugging away on the data logging.
2011 ultra mva heads, wood 408-6 cams, 103", fuel moto header with street legal se muffs.
Anyone see that the throttle plate is about 5 degrees more than the twist grip? Stock settings on that so I assume since I am at 5 degrees throttle plate @ idle you add the twistgrip opening degrees to that base number.
Old Jun 20, 2011 | 09:20 PM
  #758
iclick's Avatar
iclick
That's it, and you make three so far having this exact problem, but the first I've heard about with a late-model bike. I've reported this to DJ. This seems to affect only the gauges and PV operation, not datalogging, so if you aren't using the display function you likely wouldn't notice any problem. BTW, I've been told that we should not be running the engine when the O2 sensors are installed in but not connected. This can damage the sensors.
Is anyone having this problem with the newer single-module units?
Old Jun 20, 2011 | 09:56 PM
  #759
883_dave's Avatar
883_dave
Can anyone explain why running the engine with the O2 sensors installed but not connected would damage the O2 sensors? I am concerned about this because I am currently running an open-loop only map that I got from FM because I was having a lot of low RPM/low speed surging/hunting behavior that I thought was due to the O2 integrators. My O2 sensors are still installed and connected, but not in use. The open-loop map definately fixed my problem, but I do plan to use the O2 sensors in the future for data logging/tuning so I don't want them to get damaged.
Seems to me that I lot of folks used O2 eliminators with the PC's and I don't recall hearing about this O2 sensor issue.
I really like what the PV and Jamie's tune have done for my Sportster. We have had many 100+ degree days here lately and my bike runs very well. No surging, hunting, pinging, sputtering or popping.
Old Jun 20, 2011 | 10:22 PM
  #760
FX4's Avatar
FX4
Well if this is true it may be a problem for me. Mine were disconnected for 20k miles while I ran the PCIII.
