Power Vision Information Thread
I ran that tune and took a log yesterday as I was riding. I must say, I liked how "smooth" the idle felt once it warmed up. I logged some ping on the log, but I didnt hear any audibly. It could use some more pull in the 2500rpm around 40kpa, I am sure this is a good place to start. So I am currently using PV Log Tuner to "tune" things after logging and I am wondering, is this really a good enough tool for that? The off idle throttle response (blip) was pretty good on this one but as it warmed up, it became a little less "explosive" and seemed to have a noticeable lag. It didnt cutout or stutter, just not near as quick and snappy. Anyway, thanks for taking a look at my tune and offering your time and expert advice. I am attaching the log from yesterdays ride. I do wonder how much of an impact on the tunes accuracy the outside temps are. It was 36 degrees when I was riding, so I beg the question.
Thanks all the same..
Glen
Thanks for taking the time to post the tune, I wasn't expecting that. I had just wanted to see how a log compared to good tunes in MLV. I have the free trial version but don't know wth I'm doing/seeing yet. The small log size it caps doesn't tell me much.
However the tune you posted is for a 103ci and I have a 96ci. I forgot that I had turned off Adaptive and Closed loop once I was reasonably happy with it. I've attached the tune I'm using at the moment if you'd like to look at it and tweak it some. It took me a while to control Knock and Decel pop as neither DJ or FM had a starting tune for the S&S Power Tune Dual header when I started. So I mixed a combination of True Dual and 2-1-2 tunes to start with. Since this header isn't really either one. At first I thought the VE's were kinda low especially in the upper left quarter but AT always put them back there. Most of my smoothing / blending I kept within 2% change. And then richend up my AFR. Then worked the knock out of timing, Keeping a smooth flow. It/I get off the line pretty good and it pulls smooth all the way to 5500 even fully loaded with the wife and tour pak which is where I wanted/needed to. But if you think there's room for improvement I'd be happy to try it. And I'll be sure to post about it in the open forum.
Thanks, Smokey
I removed the map and feel sure you will get the help you need from all the experts.
If I want to go beyond the TT Autotune, is there any documentation in any of the DJ manuals on the next steps beyond just installing TT? I can't find anything. I figured it might be an addition to the PV manual, but I don't see any mention there and the TT installation manual pretty much is just that, how to put it on the bike..
Specifically the AFF, CLI, and NEW VE values.
So lets say my log show an AFF of 100.8 and a CLI of 100, is is saying I am lean in the block? And a VE of 89 and a new VE of 88, is that saying my VE in that block is too small?
I hope the question makes sense.. ! LOL
Also, I am trying to figure out what is causing an issue with throttle blip. When I blip, it cuts out, almost stalls...
I think this is a throttle blip in the log(see below):
I have no logged spark knock...I am aware of the leaned out VE blocks in the front of the VE tables..I actually LIKE decel rumble and a little pop...LOL
Just trying to get more knowledgeable here..
I am attaching the actual log and map (zipped).
thanks guys
Glen
VE New = VE * CLI * AFF
Andy[/QUOTE
That really didnt answer my question.. but ok... I was trying to get a better understanding at reading the logs manually.
Thanks
Glen
