Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
The 20 ms thing is at 6000 RPM and 100% DC. This really gets to be huge on the race motors when 9000 RPM. Max allowable DC gets really easy to bounce off of.
Dog do you have access to TTS Master Tune files? There are some good reference maps in there, especially timing. Just a thought
No- I tried finding some but no dice. it seems there is no online repository of tts une files- I think you can only get access to the tune files from within the TTS device.
Andy
you're right- thanks. I did not take into account the time window is different based on rpm. so at say 3k rpm, the DC window is 40ms. based on that and looking back through all of my logs for the past week, the highest max I'm hitting is 81%
Another good use for a power vision. 3 days of riding in a down pour and extremely high wind. Lost all dash functions except infor center radio. No gauges no tach or speedo. Had my Power visioning in the bag. I have not used it to tune the 2016 yet.
Plugged it in set one of the gauge functions to speedo and road home. It also allowed me to pulled the codes. Solved a couple trouble shooting issue right away. Power vision proved right away there were no ECM issues and that it likely was just a minor water issue.
Stuck it in the bike room with dehumidifiers running all back to normal in an hour . Now to find out where it got wet.
Andy- Wmitz- thanks for the info. really odd though that no one (here or other places on the net) really knows the technical parameters behind cruise area timing and what the acceptable high / low ranges are in a performance application.
