Power Vision Information Thread
Old Jul 19, 2021 | 09:41 AM
  #9351
2deuceguy's Avatar
2deuceguy
Originally Posted by jjdaly
It's nice that DJ provides cam cruncher with the power core suite now, but it seems like it's calculating the teeth for M8s incorrectly. With the M8 flywheel teeth on the right side now and the -2 moved to the crank pin, the calculation should be different, shouldn't it?
I noticed that as well. Numbers in cam cruncher aren't even close to where they're set in the PV tunes for M8's.
Old Jul 20, 2021 | 05:22 AM
  #9352
jjdaly's Avatar
jjdaly
based on my (admittedly terrible) eyes and counting the teeth offset on the M8 crank pin to where the -2 teeth are on a twin cam it appears that they are 10 teeth different. so, perhaps the numbers in CC should have about 10 added to get those numbers? unless they change which events they are sampling at..... for example the 105 calibrations for twin cams had the IVO number for the front cylinder cam opening, but the IVC was for the rear cam closing if i recall.
Old Jul 20, 2021 | 01:43 PM
  #9353
harleyalexey's Avatar
harleyalexey
2nd Gear
i bought power vision in my country and licens from web dynojet.
i have low rider s, exhaust bassani road rage 2, air cleaner sreaming eagle, o2 sensor stock, all other stock parts.
i dowload a tune from dynojet web 16D110002401 Year: 2016-2017 Model: Dyna S 110" engine High flow air cleaner, Bassani 2-1 Exhaust
after i shitch on auto tune 4 times , MAP pressure to 30KPA.
after all i do and load custom tune the bike runs not faster or i dont feel more torque, only one i feel thet throttle blade more agresine in low range
i change rpm range from 6200- 5500 i think it is to much.
some one hoo have low rider s 2017 can send me the tune to compere with my
or i ca
n send my tune to email to check is it all ok , i hawe the LOG file
Old Jul 20, 2021 | 02:05 PM
  #9354
dieselbeef's Avatar
dieselbeef
fuel moto can help you with maps..emailed to you
Old Jul 24, 2021 | 08:24 PM
  #9355
ultraglide12's Avatar
ultraglide12
when im done with the auto tune files can you delete them on the pv or do you have to do it with software on computer?
Old Jul 25, 2021 | 06:54 AM
  #9356
tpb857's Avatar
tpb857
The only way that I know how to delete them from the PV is on the computer with the WinPV software. Very easy.
Old Jul 25, 2021 | 12:05 PM
  #9357
ultraglide12
thanx i figured that much but thought i would ask anyway
Old Aug 2, 2021 | 02:22 PM
  #9358
ultraglide12
i added 5% to the VE`s in my closed loop area to help with it cooling down how much have you guys added to help cool it?
Old Aug 2, 2021 | 07:57 PM
  #9359
dieselbeef's Avatar
dieselbeef
can you just go into pv and change rpm limit? is it in the quick tune screen?
Old Aug 3, 2021 | 03:00 PM
  #9360
ultraglide12
yes i just seen it in quick tune
