Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
anyone have this error trying to A/T ? prepairing ecu failed . i thought it was something i did but i got home and looked at the instructions and tried it again same thing?
Make sure the kill switch is on. Wont see ECU if its off.
DJ Cam Cruncher calculator for M8, correct or not?
It's nice that DJ provides cam cruncher with the power core suite now, but it seems like it's calculating the teeth for M8s incorrectly. With the M8 flywheel teeth on the right side now and the -2 moved to the crank pin, the calculation should be different, shouldn't it?
