Power Vision Information Thread
Old Nov 16, 2020 | 05:17 AM
  #9321
shanneba's Avatar
shanneba
For the Power Vision gear indicator issue, see this link:
GEAR DISPLAY NOT WORKING
Also when you select "Gear" using the advanced signals, there may be both a "gear" and "gear #" choice, choose "gear #"
For the gauges not changing colors-
Is your Power Vision firmware and Tune database up to date?
Use the PV Update program to verify.
When you selected your gauges, when you select vehicle signal, does the screen show advanced signals at the top?
Both Engine Speed and Vehicle Speed are available in both the basic and advanced selections.
Make sure you choose the "advanced" signal for the "Engine RPM" and "Vehicle Speed"
See this video at the 1:49 mark to see where you can change the signal type when selecting a gauge.
Old Nov 16, 2020 | 06:23 AM
  #9322
RoxSy's Avatar
RoxSy
https://youtu.be/Ycm4-KNGz14
Thank you for your reply.
First of all, yes, the PV is all up to date.
The link you provided just point me to a couple of posts above and I couldn't find anything related ...
The PV is displaying vehicule speed and RPM properly but is not showing the color changes I implemented.
It wasn't displaying gear indicator though, as mentionned.
I'll try the advanced tab and see if it changes anything.
Be safe.
Old Nov 16, 2020 | 10:07 AM
  #9323
shanneba's Avatar
shanneba
Sorry about the link not working, not sure how I screwed that up
Try this one
https://www.dynojet.com/amfile/file/.../category/115/
Old Nov 16, 2020 | 10:53 AM
  #9324
RoxSy's Avatar
RoxSy
Try this one
Thank you.
The link worked but this is not my problem.
Maybe I wasn't clear enough.
The gear display is working properly on the bike gauge but it is not working in the Powervision itself.
But maybe it is not the correct tab.
I'll try gear# in the advanced tab and see if it works better.
Thank you anyway :-)
Old Nov 17, 2020 | 11:51 PM
  #9325
Red Dragons's Avatar
Red Dragons
I've noticed after running several log tuning sessions, when I'm running a closed loop map with adaptive control on, there will be fuel corrections in areas of my map that aren't within closed loop cells. I run a fairly restricted closed loop area in my map, and I don't want it pulling fuel from areas that are supposed to be open loop, yet according to the logs, it does. How would it even be able to do this with the stock narrow band sensors...below 14.2AFR the sensors don't even work. So how can the ECM be making corrections in areas of the map that are say 13.5?
Should I turn off adaptive control to prevent this?
Old Nov 18, 2020 | 04:26 AM
  #9326
shanneba's Avatar
shanneba
Turning off AFF would eliminate the AFF values at higher throttle, you would then only see the CLI values in the "Closed Loop" part of your logs.
If your VE values are correct you should see only small AFF value changes. Somewhere around 98 to 102, +- ~ 2%
(it seems like the PV/ECU only reports the AFF in 0.8 increments)
It seems to me the AFF seems to adjust for differences mostly in air pressure, following the BARO PV log data,
there may also an offset based on the Intake Air temperature.
The Adaptive Fuel Factor is extended to higher throttle positions.
It seems to me that the AFF you have in an rpm range at 25-30% throttle is what is extended out to 100% throttle.
The O2 sensors do continue to have a voltage even at 12.5 to 1, but since a very small change in voltage means a
larger change in AFR they are not as "accurate", the smallest O2 voltage change the PV/ECU will show is 0.02 volts.
With E0 gasoline at 12.8:1 O2 voltage should be about 0.88, at 0.86 (-0.02v) AFR is ~13.2:1 and at 0.90 (+0.02v) AFR is ~12.2:1
Old Dec 31, 2020 | 11:31 AM
  #9327
Paul-S's Avatar
Paul-S
Is there a preferred spark plug to run with the PV with target tune? I'm wondering about the Iridium plugs. They worked fine with my T Max.
Old Dec 31, 2020 | 01:16 PM
  #9328
smitty901's Avatar
smitty901
Iridium plug are a waste but if you like them run the Power vision don't care.
Old May 27, 2021 | 08:08 AM
  #9329
shanneba's Avatar
shanneba
Has anyone tried the FM PV firmware update to fix gauge freeze?
We’ve seen certain Dynojet Power Vision PV-1 equipped J1850 bikes experience a “Bus Error” on their odometer and sometimes this may cause security to shut the bike off upon start up.
This only occurs when the Power Vision is plugged in any only a few bikes appear to be affected.
There is Power Vision firmware that will resolve this,
we’ve also seen this firmware fix gauge freeze that has affected some bikes
Fixing Bus Error and gauge freeze for Power Vision PV-1
Old May 27, 2021 | 08:09 AM
  #9330
iaminsider's Avatar
iaminsider
I tried it earlier this week.... Didn't fix it for me.
