Power Vision Information Thread
The kit with WB sensors looks really nice and I can't wait to try it. However, I am still baffled why the flat, non-radiused bungs are placed in this kit. And on top of that, they are flat "set in" bungs and very thin flimsy quality. Entirely wrong application for our bikes.
If you use the included bungs as is, you may end up with a really ugly weld job and your o2 sensor tips will be pointing upwards, collecting condensation, and they will prematurely fail. Someone at DJ was not paying attention when assembling this kit.
Anyway, expect to spend another $20+ on good stainless angled, radiused bungs if you need to modify your pipes to use the WB sensors.
It should look like this:
45 degree curved bung for v-twin wideband o2 sensors
From everything I gathered, (and I could be interpreting wrong) the bung can be either straight or angled depending on space requirements.
Or as you said previously the manufacturer is possibly wrong?
It would seem that condensation would be avoided if installed between 9 and 3 o'clock position as they say.
Here is some info I found concerning placement and condensation:
NSTALLING THE WELD BOSS—MOTORCYCLE
2 Mount the weld boss in a manner that reduces
the risk of moisture contamination on the
sensor. Condensation can build up in the
exhaust pipes and potentially damage the
sensor.
3 Ideally, you should orient the weld boss so the
sensor is between the 9 o'clock and 3 o'clock
position (reading clockwise) as shown in
Figure H. A 10° inclination off the horizontal
plane should be considered a minimum.
http://www.powercommander.com/downlo...8200017.03.pdf
sensor.
Should I do a TT-AT run with my AFR target table as is (various targets across table), or would it be better to set the entire table to say 13.2, as is done with most dyno tuning sessions? Should I disable accel enrichment? What is going to give me back the most accurate WB VE tuning results?
Have to ask since there is really not enough data yet out there in this product and best ways to use it optimally for performance tuning. Would be really nice if we had an 'official TT info thread' to build on.
Andy
It would seem to me that leaving things enabled like accel enrich or decel enlean would skew the auto tuning results- unless those are disabled during the TT's AT process.
