Power Vision Information Thread
Old Jun 23, 2011 | 12:30 PM
  #791
883_dave's Avatar
883_dave
Originally Posted by JustDennis
Here is a start that I created quickly using some of Jamie's posts, my notes and adding information I learned from tuning. This is a first pass and will gladly take suggestions and corrections. Let me know if this is helpful. I tuned first with the stock O2 sensors and am now using the Autotune Wideband sensors. I can add that to the instructions later unless DynoJet comes out with a better manual first. Iclick, we can collaborate on this if you like. If this is helpful, I can take input and create a more comprehensive manual if needed.
http://www.box.net/shared/i66qvn4xf1s2xp7fgy8v
Thanks for the information. One question. After datalogging and developing a "new and improved" tune/calibration and downloading it to the ECM is this new tune then used as the base tune/calibration to make a new value file for future datalog/log tuning sessions? I assume that each time you datalog you would want to build on the most recent updated tune, not the base calibration that you started with. Am I correct? Thanks.
Old Jun 23, 2011 | 01:35 PM
  #792
aclundwall's Avatar
aclundwall
That's the way I'm doing it... I create a new value file from the tune that's currently loaded while i'm logging.
Old Jun 23, 2011 | 01:45 PM
  #793
iclick's Avatar
iclick
Originally Posted by GotMy11SG
Got it, thanks!
It's up to 860 now, and don't use 857 if you have it. I'm told it has a bug and was only out for a short time the other day.
Old Jun 23, 2011 | 01:47 PM
  #794
JustDennis's Avatar
JustDennis
You are correct. Once you update the tune with this process, it becomes your "base" tune and you use it to repeat the process. Continue to repeat the cycle until the changes are minimal. You should always see minor VE changes due to are the variables but once you have covered as many areas of the map as possible and the changes are a small percentage, you should be set.
Of course some of us are never satisfied and continue tweaking...
Old Jun 23, 2011 | 01:53 PM
  #795
iclick's Avatar
iclick
I'm not seeing the MPG correction or adjustment option in WinPV OR on the PV itself. Hmmmmn...
You adjust the MPG using two parameters. One is the new "MPG adjustment" in the edit section of the PV. To access it, go to the PV > Program Vehicle > Load Copy > Load Copy of Current, then drop it in a Custom Tune slot. Open it, then Edit, which should show you several editable parameters, one of which is MPG Adjustment. This is a misnomer since it really only changes the fuel-used parameter. Whatever the number that's in there, in your case subtract 10%, which should lower the fuel-used by that percentage. Tweak it until it matches the actual fuel used, which will probably take a few tankfuls. BTW, I don't know if you need to do the Load Copy rigmarole described above or not, but that's the way I was told to do it.
The problem with getting MPG just right is that it involves MPG Adjustment and VSS (Vehicle Speed), which is the Speedometer Calibration in WinPV. This adjusts the speedometer in the ECM, but this may be different than what you see on your fairing gauge. My ECM speedometer is 1.2% slower than my fairing speedometer, which I have set correctly and that's where it's going to stay. So, in my case I'll need to select between an accurate Fuel Used gauge or MPG gauges, and I'll take the first. I will be seeing a correct Fuel Used gauge, once it is tweaked, but my MPG will be off by 1.2% or thereabouts. I hope this is clear.
Edit: MPG Adjustment is now in WinPV too.
Old Jun 23, 2011 | 02:07 PM
  #796
CrusingHarley's Avatar
CrusingHarley
Originally Posted by iclick
The MPG correction adjusts only the fuel-used parameter, and it is only available if you edit the parameters from within PV. You can get MPG and Fuel-Used both correct only if you mess with the Speedometer Calibration too, and since I have the latter set for a correct speedometer I'm only willing to use Fuel-Used. I am getting it tweaked, but the speedometer cal in the ECM is different from what is seen on the fairing gauge. So, when I get Fuel-Used correct my MPG will not be correct since I would have to throw my speedo a bit fast or slow, which I'm not willing to do. As it sits, I have Fuel Used about right and MPG is ~1.2% pessimistic, which is close enough.
Hope this isn't confusing. I just read it back and now I'm confused.
Ok now I am confused. For me, the MPG is available in the PV and WinPV. I am using it to adjust my fuel ecomony (MPG) and it appears to be working. I am in the ball park and need to fine tune it.
Am I misunderstanding something?
Old Jun 23, 2011 | 02:34 PM
  #797
JustDennis's Avatar
JustDennis
I see it both in PV and WinPV. It is only available in WinPV on calibrations created with the new revealed features OR You can "see" it on your current tune file by loading a copy of the current tune to the PV from the bike's ECM and then using WinPV to get tune from the PV. Once you do that you can save it to your PC and use that version to access the new features. You can use it to adjust MPG as you stated.
Old Jun 23, 2011 | 03:35 PM
  #798
iclick's Avatar
iclick
No, I'm the one who's confused. The procedure I mentioned above worked with older FW and WinPV versions, at least in the past month, and is still editable in the PV--but now I see this parameter is in WinPV. Okay, that makes it simpler, but you change it as mentioned above, and it only changes the fuel-used parameter...that is unless they've changed that too. I had recommended making it a one-parameter calibration rather than getting VSS involved, so I'll double-check to make sure its function is the same and will report back.
Dennis has it right. I can't see MPG Adj. in WinPV on older tunes, and the only way for me to see it there is to Load Copy of Tune from the PV and move it to WinPV. I can then edit, save, etc. and it'll be there in the future.
Old Jun 23, 2011 | 05:51 PM
  #799
dropone's Avatar
dropone
Whew and thought this was going to b easy.
Old Jun 23, 2011 | 05:54 PM
  #800
papifun's Avatar
papifun
thank you JD..rain here for next few days..will give your procedure a try and post feedback..i assume going through the AT basis my mpg per tank should get better.. ride safe..
