Power Vision Information Thread
Old Jun 23, 2011 | 06:46 PM
  #801
Heatwave's Avatar
Heatwave
Member
Originally Posted by iclick
No, I'm the one who's confused. The procedure I mentioned above worked with older FW and WinPV versions, at least in the past month, and is still editable in the PV--but now I see this parameter is in WinPV. Okay, that makes it simpler, but you change it as mentioned above, and it only changes the fuel-used parameter...that is unless they've changed that too. I had recommended making it a one-parameter calibration rather than getting VSS involved, so I'll double-check to make sure its function is the same and will report back.
Dennis has it right. I can't see MPG Adj. in WinPV on older tunes, and the only way for me to see it there is to Load Copy of Tune from the PV and move it to WinPV. I can then edit, save, etc. and it'll be there in the future.
I also can't see the adj mpg feature and I've updated all PV firmware to the latest version. I'll try the "Load Copy" approach from the ECU. Seems odd and not well thought out that this would be the only way to add new features to older tune files. DJ needs to provide an "update tune file" from within WinPV or they are going to have alot of confused users as they begin addin new features to future tune file formats.
Currently the only tune file adjustments available in Pro mode for my tune files are RPM Limit, Adaptive Control and Idle RPM Adder. I don't find these adjustments to be terribly helpful from the PV. Hopefully the Load Copy approach from the ECU will be more successful to view the latest adjustment features.
Old Jun 23, 2011 | 07:01 PM
  #802
CrusingHarley's Avatar
CrusingHarley
I agree,
Right now the only way to acquire the latest enhancments is to load current copy and bring that into WinPV. I have done this with every firmware update and always notice the new tables.
Old Jun 23, 2011 | 07:08 PM
  #803
dropone's Avatar
dropone
Thanks iclick. Load copy was the only way I could get MPG Adj.
Old Jun 23, 2011 | 07:26 PM
  #804
Heatwave's Avatar
Heatwave
Member
You adjust the MPG using two parameters. One is the new "MPG adjustment" in the edit section of the PV. To access it, go to the PV > Program Vehicle > Load Copy > Load Copy of Current, then drop it in a Custom Tune slot. Open it, then Edit, which should show you several editable parameters, one of which is MPG Adjustment. This is a misnomer since it really only changes the fuel-used parameter. Whatever the number that's in there, in your case subtract 10%, which should lower the fuel-used by that percentage. Tweak it until it matches the actual fuel used, which will probably take a few tankfuls. BTW, I don't know if you need to do the Load Copy rigmarole described above or not, but that's the way I was told to do it.
The problem with getting MPG just right is that it involves MPG Adjustment and VSS (Vehicle Speed), which is the Speedometer Calibration in WinPV. This adjusts the speedometer in the ECM, but this may be different than what you see on your fairing gauge. My ECM speedometer is 1.2% slower than my fairing speedometer, which I have set correctly and that's where it's going to stay. So, in my case I'll need to select between an accurate Fuel Used gauge or MPG gauges, and I'll take the first. I will be seeing a correct Fuel Used gauge, once it is tweaked, but my MPG will be off by 1.2% or thereabouts. I hope this is clear.
Edit: MPG Adjustment is now in WinPV too.
Thanks Iclick. I was able to access the new PV adjustment features such as MPG Adj and Speedo Calibration. Seems like a very clunky approach to add new adjustment features to existing tune files. You might want to consider alerting DJ that they need to build an "Update" feature into WinPV to upgrade previous tune files with the latest adjustment features they are adding to the PV and WinPV. To not do so soon before adding more features is definitely going to be a problem for users that have older tune files. Particularly if the only way to add the new features is to first load the tune file to the bike using the old file, then "copy the ECU Tune" back to the PV in order to add the latest tuning features.
On a separate subject I'm alittle disconcerted with the changes that the PV made to the original tune file when it updated the file after copying it from the ECU.
Specifically I used the "Compare" feature to compare the original old tune file to the new one that was copied back to the PV from the bike's ECU.
The following changes were made to the original tune file:
  • VE Front was modified in many cells. Small changes and possibly rounding issues.
  • VE Rear was modified in many cells. Small changes and possibly rounding issues.
  • Minor changes were made to the injector size. Possibly rounding adjustments.
  • Minor changes were made to a large block of cells in the Lambda AFR table. Possibly rounding adjustments.
  • I checked all other Compare parameters and found no other changes.
I paid good money to have my current tune file professional tuned and I see no reason why the PV or WinPV software should be modifying these tables (even small rounding adjustments) when it's simply copying the data back from the ECU. What other changes are being made in the background when the PV is suppose to be making an exact "Copy" of the ECU file.
Thoughts from others?
Old Jun 23, 2011 | 10:17 PM
  #805
iclick's Avatar
iclick
Originally Posted by dropone
Whew and thought this was going to b easy.
Compared to quantum physics this is easy, but just by a smidgeon. Also this news flash: MIT is now offering a new course called "Power Vision and the Space-Time Continuum 401." Maybe they have a correspondence course for us.
Old Jun 23, 2011 | 10:36 PM
  #806
Dustball's Avatar
Dustball
FYI: For some 2004 (upgraded ECMs) and 2005 and up bikes, Yes. However, those with the older ECMs in 2004 and below the Speedometer Calibration doesn't do squat. My MPG and fuel used are now less than 1% of "truth at the pump" and I don't pay attention to the PV's distance.
Old Jun 23, 2011 | 10:40 PM
  #807
iclick's Avatar
iclick
I'll make that recommendation.
I ran into this over a month ago when testing the MPG parameters when in beta testing. I sent them my latest tune and they converted it to reflect the MPG error I was getting, but this parameter was not alterable by me at that time and was only a test. When I got it back it had the values rounded as you observed. Below is my question and the explanation I got. Rounding occurs to the nearest .5, but if the value is at .0 or .5 it remains unchanged, at least in the VE tables. I agreed that it wasn't significant and apparently the ECM tables do the rounding anyway, or at least that's my interpretation.
Me: Some of the values within tables have been changed, none very much. The most notable are those in the VE tables, which have all been rounded to the nearest 0.5. This isn’t significant, but why was this done? Other tables have one or two values changed, never very much, leaving the others alone. Can I just move all tables from the old map back to the new?
DJ: As far as the table values being "changed" when flashed to the ECU and read back, that is as designed. I realize you didn’t do a read on your current tune as a “.stk”, and then convert to a .pvt, and then sent that to us, but that’s essentially what we did (convert an .stk to .pvt). We took a known, good .stk file (.pvt’s don’t include all the calibration data that a .stk does) and converted that to a .pvt and included the MPG tweak. Rather than limiting what the user types in to fit EXACTLY onto the ECU, we let them get within 1 decimal place. For example, some tables might only accept .0,.25,.50,.75 but we'll let them enter the 2 full decimal places. TTS/SuperTuner would limit them to those 4 values. We did that for two reasons: 1) Easier to program/manage 2) Easier for users who are typing and cutting/pasting/doing math/pvv importing on cells. The values will get clipped when flashed, not whenever modified, if that makes sense, so error won't propagate through movements/math.
So long story short, this isn’t an issue. It’s a by-product of the flexibility of our software, and a limitation of the ECM’s ability to handle precision.
Old Jun 24, 2011 | 06:52 AM
  #808
JustDennis's Avatar
JustDennis
Originally Posted by papifun
thank you JD..rain here for next few days..will give your procedure a try and post feedback..i assume going through the AT basis my mpg per tank should get better.. ride safe..
One caution on mpg, I found while tuning my mpg was terrible because I ride so differently to hit other areas of the map. Once you get your tune nailed down and return to normal riding habits you can check your mileage. Seems like I normally lose 3-4 mpg while doing the tuning runs but that is understandable.
Old Jun 24, 2011 | 06:55 AM
  #809
Heatwave's Avatar
Heatwave
Member
That makes sense in the VE tables, however I'm somewhat concerned with that approach on the injector size and AFR (lambda) tables. My injectors are 5.3gm/sec and when the "copy" process from the ECU handled the file, it lowered the size to 5.28. This seems counter to the explanation above.
Likewise, the AFR table lowered the lambda by .001 across the table out to about 70% and down to 3000rpms. Doesn't make sense to me why these changes are occuring and it would appear to be a different reason then the changes made to the VE tables.
I-click, any chance you can get an explanation?
Old Jun 24, 2011 | 07:37 AM
  #810
JustDennis's Avatar
JustDennis
If you think about this though it makes sense. Since previous versions of WinPV did not know about these "new" tables, the only place to get the data is from the ECM on your bike. These new tables aren't really new. They have been in the stock calibration all along.
When you load the tune from your bike you are bringing the data from the ECM into the PV and then into WinPV so you can see or edit it. DynoJet may be able to automate the procedure but the process will remain the same. The "new to PV/WinPV" data will have to come from the ECM on the bike.
