Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I had the same problem immediately after install the "Love Jugs" Mighty Mites fans and plugging them into the accessories circuit with a Deutsch splitter. Worked ok for about 5 - 10 minutes of riding and then the gauge values went blank but the 6 gauge screen was normal, just no sensor values. After discussing it with both Dynojet and Fuel Moto whereas both was sure it was RF interference so I removed the seat/tank and checked/relocated everything from the PV cord and put everything back together - results was NO CHANGE!! I then purchased a new cable from Dynojet and ran it over the tank and under the console - results was NO CHANGE!! My next step was to go for a short ride of about 7 - 8 miles with the fans turned OFF, and everything worked as normal. So after absolutely identifying the source I cut off the Deutsch connection on the end of the fans plug and hard wired directly to the battery and issue was completely solved. I don't understand why connecting to the accessories circuit caused the RF interference, but it did. My problem might have just been a specific issue with the power for the fans, but I thought I would share my problem/resolution in hopes that it may benefit others!!
Roger
Roger, I had exactly the same problem as you. I also moved both the PV cable and the LG wiring around to separate them from each other. Didn't resolve it. I re-wired the fans directly to the battery and have not had any issue since.
Hi I was wondering if someone could help me with a question I have? On my P.V. where I get my logs from,there's a bunch of old PVAT files that i dont use anymore. My question is can I delete them without doing any harm to my P.V. or ECM/tune? Thanks for your help!
They are from auto-tune sessions. They are no longer needed by the PV.
If you use the old Log Tuner program, you can save them and run them through it, but that is about all the use they are. The PV now does by itself what the Log Tuner program used to do.
Where can I find instructions on how to load a tune from FM? Say I put cams in my bike email FM & they send me a email I presume how do I load it to PV?
you just go to your email and download the attachment that was sent from Fuel Moto, and save it to a folder you can go back to.Then you just load it to your P.V then load it to your ECM.
Here is a helpful video we put together that walks you thru the steps of downloading the map from your email and sending it to your Power Vision.
Either there isn't anything related to my question or the search function on my phone just isn't cooperating.
Im trying to use the autotune pro feature on my 06 roadking. 98" big bore kit. Reaper cams. And v&h pro pipe with high flow air cleaner.
When using the autotune feature I leave the screen on the datalog screen. While riding the screen dims and says VE+ Repeatedly under load. In the manual this is called a condition that means the conditions are changing too rapidly or moving between VE tables.
Is this normal? When it displays this condition it appears as if nothing is being recorded in the cell that it was in until i back off throttle or find a sweet spot where it starts working again.
I have a question on how to get your bike to sound like a Harley coming off a mountain letting off gas (this is only way I know of how to describe it sorry) and let say your running straight pipes and for it growl. Another way to describe it bellering. Like fuel cuts off no popping. When I had a v&h fuelpak and say coming down a mountain with no throttle after so long it would seem like to me like fuel would cut off & hold back. now with the PV it does not hold back any or beller so to speak. It runs 100% better but different. A heck of lot smoother. Glad I bought it but don't know enough on what settings could or would change this feature.
