Power Vision Information Thread
"Once the (Target Tune enabled) tune is flashed to the ECM, you should run a couple AutoTune Target Tune sessions to dial in the tune that was flashed.
When you run the AutoTune session, be sure to select the Target Tune from the custom slot on the Power Vision. If you are running
additional AutoTune sessions, be sure to select the resulting tune from the previous session. Next, be certain to select the correct
AutoTune option, Dynojet Target Tune Wideband Kit. The AutoTune process adjusts the VE tables in the tune."
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Instructions can be found here: https://university.fuelmotousa.com/h...-Full-Recovery).
If I understand it correctly, first you get the bike tuned using their autotune feature.
Once the bike is completely tuned then remove the OEM O2 sensors and weld bungs into the exhaust.
Then run the bike with Target Tune (and its sensors) to accomplish what? Correct tuning issues (mistakes?) from the autotune results?
Why would someone take a great running bike from autotuning and remove perfectly good high speed O2 sensors and replace the sensors with slower reacting sensors?
Please help me understand what I am missing here. Is this a product developed to fill a need that doesn't exist?
Bob
Bob
With ANY system the VEs MUST be calibrated (tuned) or expected results will/can not occur.
The thing is...when the VEs are correct any changes to AFR targets provide reliable results.
Bob
Instructions can be found here: https://university.fuelmotousa.com/h...ull-Recovery).
Thank you for your suggestion but wouldn't think the folks would do this at dynojet when they had so long? First we are putting it on another bike and see what happens and if it still blanks out your suggestion will be next. Thank you for responding. I run your 2:1:2 headpipe on my bike.
Problem solved!!!!
Roger
Problem solved!!!!
Roger
