TSSM- Code
Old Apr 2, 2011 | 07:40 PM
Trikerjon's Avatar
Trikerjon
Arrow TSSM- Code
Is there a way to find the stored code on a TSSM ? I`m told without the code the TSSM is useless.........HELP
Old Apr 2, 2011 | 08:46 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Not worthless, you can do the reset or relearn password procedure.
Reset:
step # 1. move handle bar kill switch to off position
step # 2. turn your ignition key: on-off, on-off then on
step # 3. hit the left turn signal twice.
your turn signals and indicator light will flash 1 - 3 flashes
step # 4. hit the right turn signal once.
turn signals and indicator light will flash once.
step # 5. hit the right turn signal once.
turn and indicator signals will flash twice.
step # 6. hit right turn signal once.
turn and indicator signals will flash three times.
step # 7. hit left turn signal once.
turn and indicator signals flash to indicate error code
(see error code thread)
step # 8. to now clear codes, hit left turn signal and hold down for 6 seconds until confirmation.
turn and indicator signals flash twice.
step # 9. turn the ign switch to off
Old Apr 2, 2011 | 08:48 PM
KBFXDLI's Avatar
KBFXDLI
Relearn;
http://www1.hdtalking.com/tn717s3.jpg
Also, make sure to get a new fob battery
Old Apr 2, 2011 | 09:22 PM
lewain's Avatar
lewain
I have a used TSSM that I installed on my 2008 Roadking. I have tried the new learn procedure to no avail. I took my bike to my local dealer and they tried to install and told me that once they hook up unit it immediatly goes into an "Armed State".
While it is in this "Armed State" nothing can be done to bike.(All of this is what I had already deducted). Aparently the person that had the TSSM on their bike changed the code and now the TSSM is not reprogramable.
Has anyone heard of this and or know of a solution short of buying a new TSSM?
Old Apr 4, 2011 | 11:56 AM
Trikerjon's Avatar
Trikerjon
Beware of buying or selling TSSM units unless you know the 5 digit security code. The unit won`t work !!!!! It goes into an alarm state and the dealer or you can`t retrieve the code.......rendering it USELESS.
phillyrube
Electrical/Lighting/Alarm
Nov 22, 2014 05:52 PM
Rugged Racing
Jun 18, 2014 06:07 PM
Reindeer
11
Sep 27, 2012 06:34 AM
Cbones
Aug 30, 2012 02:34 AM
Ric27
Apr 3, 2011 04:21 PM
